3750-X upgrade
NeilAtkinson
Hi there, I am an end user and not a network engineer.
I have eight 3750-X network switches that are not used for anything fancy other than Netflow export (was is CRITICAL).
I need to budget to upgrade these switches and am looking for advice on which switches to upgrade to.
Many thanks, Neil
2 Accepted Solutions
The "smallest" Cisco Catalyst that supports NetFlow is the 9200.
balaji.bandi
You want to uplift the switch model from exiting model to new Models.
Cisco 3750(all models)EoL
New Trends is Cat 9K ( depends on budge you can choose) Cat 9200 Cat 9300 good to access switches replacement of Cat 3750.
Netflow support has that models
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9000/nb-09-cat-9k-aag-cte-en.html
Hope this make sense ?
BB
Leo Laohoo
Hi Leo, many thanks but i am not looking to upgrade the IOS I am looking to upgrade or perhaps should have said replace the switch with a modern version that is netflow capable.
balaji.bandi
BB
