3750E Output Drops when interface not full.
Net Admins
I am having a switch with constant output drops, however the bandwidth usage is low for the interface.
This is just a trunk interface, what could be causing the switch to drop so many packets? Is there a limit of the number of packets per interface?
sw3750e-235#sh int gi1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001d.7066.f898 (bia 001d.7066.f898)
  Description: "sw253 Gi1/0/45"
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 17/255, rxload 16/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:02, output hang never
  Last clearing of "show interface" counters 1y23w
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1247484253
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 63739000 bits/sec, 16377 packets/sec
  30 second output rate 70402000 bits/sec, 14699 packets/sec
     923325352621 packets input, 384250695979115 bytes, 0 no buffer
     Received 1800925272 broadcasts (1527218218 multicasts)
     0 watchdog, 1527218218 multicast, 0 pause input
     631932585697 packets output, 352187254570142 bytes, 0 underruns
     reliability 255/255, txload 18/255, rxload 29/255
  Last input 00:00:01, output 00:00:06, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1247489999
  30 second input rate 113891000 bits/sec, 18977 packets/sec
  30 second output rate 73515000 bits/sec, 15639 packets/sec
     923327052223 packets input, 384251849315561 bytes, 0 no buffer
     Received 1800929232 broadcasts (1527221362 multicasts)
     0 watchdog, 1527221362 multicast, 0 pause input
     631933974629 packets output, 352188051573131 bytes, 0 underruns
interface GigabitEthernet1/0/24
 description "sw253 Gi1/0/45"
 switchport mode trunk
 load-interval 30
 spanning-tree mst 0 cost 1200
end
12 Replies 12
is this a stack member or a standalone switch ?
It's a standalone switch doing L2 switching only.
I am inclined to say that the interface buffers of this device are no longer enough to the amount of packets being transversed through this interface.
there is a bug that causes the interface to show an incorrect output error value.
When you issue the command:
show platform port-asic stats drops
do you see the same drops ?
ye, it seems the frames in queue 3 weight 2 are rising every time i run the command
sw3750e-235#show platform port-asic stats drop gi1/0/24
  Interface Gi1/0/24 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 789076
      Weight 1 Frames 21
      Weight 2 Frames 2
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 1352479902
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
do you QoS enabled on the switch ? If not, enable it with 'mls qos' global command:
Once enabled, post the output of:
sh mls qos int gi1/0/24 statistics
sh mls qos maps dscp-output-q
sh mls qos queue-set
Depending on the output, we can try changing the queue-set buffers...
QoS is not enabled in the device
I understand what probably is happening the hardware queue for this interface is always full, for this kind of traffic. Is there a way of making more buffer for this queue of traffic while sacrificing a little from the other queues?
My doubt is in the other queues what kind of traffic lands there?
#sh mls qos int gi1/0/24 statistics
GigabitEthernet1/0/24 (All statistics are in packets)
  dscp: incoming
  0 -  4 :    74558130     12048319   3906982273      1637836    272519512
  5 -  9 :      882498      5673512       534401       574851        16680
 10 - 14 :       18649           66        18839         7671          266
 15 - 19 :         968       358227           12        99375            8
 20 - 24 :       24479           14           12           20        83786
 25 - 29 :          17   2280477888           10         2421            7
 30 - 34 :          12            7          327           14       106982
 35 - 39 :           9           16           10           23            3
 40 - 44 :     1735553            9          211           14          119
 45 - 49 :          13     93712898           13   2686244510         1159
 50 - 54 :       10722           75         1276           57          160
 55 - 59 :         115      4353657           10           10           13
 60 - 64 :           8           14           14            7
  dscp: outgoing
  0 -  4 :  3819663708       378674    856647444       184420    418599055
  5 -  9 :      132241       146961        18075        90565          917
 10 - 14 :         880            5           13            1           12
 15 - 19 :           0        31436            2         1538            1
 20 - 24 :          23            5            3            3          852
 25 - 29 :           3       302434            1         2121            2
 30 - 34 :           2            1           42            1       106377
 35 - 39 :           2            3            2            5            0
 40 - 44 :      157612            2            4            3            3
 45 - 49 :           3         5925            3   2491840645        13849
 50 - 54 :     1647439          259        20039         3794        10877
 55 - 59 :         654        98325            0            1            2
 60 - 64 :           3            2            3            2
  cos: incoming
  0 -  4 :  3028725714            0       416701           80            0
  5 -  7 :        5588   1804712692     27812539
  cos: outgoing
  0 -  4 :  4230299207            0            0           30            0
  5 -  7 :         298     14834609     12180378
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           2           0           0
 queue 1:  1686003605    62706982    23358854
 queue 2:           0           0           0
 queue 3:           0           0  2485322918
  output queues dropped:
 queue 0:           0           0           0
 queue 1:      789076          21           2
 queue 2:           0           0           0
 queue 3:           0           0  1355017441
Policer: Inprofile:            0 OutofProfile:            0
#sh mls qos maps dscp-output-q
   Dscp-outputq-threshold map:
     d1 :d2    0     1     2     3     4     5     6     7     8     9
      0 :    02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01 02-01
      1 :    02-01 02-01 02-01 02-01 02-01 02-01 03-01 03-01 03-01 03-01
      2 :    03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01 03-01
      3 :    03-01 03-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
      4 :    01-01 01-01 01-01 01-01 01-01 01-01 01-01 01-01 04-01 04-01
      5 :    04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01 04-01
      6 :    04-01 04-01 04-01 04-01
#sh mls qos queue-set
Queueset: 1
Queue     :       1       2       3       4
buffers   :      25      25      25      25
threshold1:     100     200     100     100
threshold2:     100     200     100     100
reserved  :      50      50      50      50
maximum   :     400     400     400     400
Queueset: 2
Queue     :       1       2       3       4
Hello.
here is what I have come up with to reconfigure your interface queues. Make sure you have qos globally enabled (mls qos):
sw3750e-235(config)#mls qos queue-set output 2 buffers 10 30 30 30
sw3750e-235(config)#mls qos queue-set output 2 threshold 2 3100 100 100 100
sw3750e-235(config)#mls qos queue-set output 2 threshold 3 3100 100 100 100
sw3750e-235(config)#mls qos queue-set output 2 threshold 4 3100 100 100 100
sw3750e-235#conf t
sw3750e-235(config)#int gi1/0/24
sw3750e-235(config-int)#queue-set 2
sw3750e-235(config-int)#end
Make sure queue set 2 is assigned to your interface:
sw3750e-235#sh run int gi1/0/24
switchport mode access
mls qos trust dscp
queue-set 2
Check if you still see output drops.
Another option would be to configure priority queueing on the interface:
sw3750e-235(config-if)#priority-queue out
sw3750e-235(config-if)#end
Then, the following sends all affected traffic to the priority queue:
sw3750e-235(config)#mls qos srr-queue output dscp-map queue 2 threshold 1 0 2 26 48
sw3750e-235(config)#mls qos srr-queue output dscp-map queue 3 threshold 1 0 2 26 48
sw3750e-235(config)#mls qos srr-queue output dscp-map queue 4 threshold 1 0 2 26 48
Joseph W. Doherty
The 3750 series is a bit infamous for egress port drops.  Bursty traffic often is dropped due to lack of interface buffering, even when overall bandwidth utilization is low.
Port assignments can influence drop rates.  The 3750 provides 2 MB of buffer RAM per 24 copper ports and per the uplink ports.
Also, if QoS is enabled, by default the 3750 uses a buffer allocation scheme that reserves half of the buffer RAM to ports and further reserves that per hardware queue.  (I've had some wonderful decreases in egress drops [from several drops a second to 1 or 2 drops a day] by queue-set settings.  [I see one of George's post changes queue-set settings too, although my approach is pretty different from his.])
Thanks for the help Josep and George.
I have got one question though, if you are dealing with a situation where it's not just bursty traffic, the switch is constantly having discards out or output drops due to excessive amounts of packets having to be sent out.
Will changing the QoS settings help in this case? According to what you said, the RAM buffer is shared, splitting the traffic my multiple interfaces could also have a positive effect?
If you're dealing with long-term oversubscription, a common long term fix is to add bandwidth.  Another solution, which may work both short term and long term is an advanced drop management strategy.  Other solutions deal with 3rd party traffic management devices and/or host changes.
As advanced drop management strategy is often implemented using advanced QoS techniques, yes QoS might help.
Also yes, using multiple interfaces may have a possible effect, if they don't share the same physical buffer, and you're not dealing with long-term oversubscription.
I was just reading a previous post of yours:
On the 3750 series, when dealing with bursty traffic, I've had great success by tuning the hardware buffers.  Basically, rather than using the defaults, which reserve 50% of your buffer space to interfaces (and such reservation is split across each egress queue [this all assuming QoS is enabled]), I reduce the interface reservations (putting more RAM into the common pool) and increase how much buffer RAM an interface can dynamically have.
Can you come forward which kind of values do you use?
mls qos queue-set output A threshold B C C D C
A=1 or 2; NB: ports by default use queue-set 1
B=1, 2, 3, 4; queue number, I normally use same value for all 4 queues.
C=tail drop value; I normally use same value for all 3; I start at 400, which is max value for older IOS versions, later versions support up to 3200, so I might use 800, 1600 or 3200
D=buffer reservation; I lower, I might use 25, 10 or even 1
