Inter VLAN routing on 887VA-M IOS v12.4
ngrjaznov
Hi All,
I am trying to set up router with couple vlans but it does not seem to be willing route between them.
the goal is to go from 10.0.2.0 network on to WAN interface xxx.xxx.xxx.76,could some one advise what am i doing wrong?
Current configuration : 2096 bytes
version 15.2
no service pad
hostname VRN-SRRTR01
boot-start-marker
boot-end-marker
enable secret
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 10.0.2.0 10.0.2.100
ip dhcp excluded-address 10.0.2.240 10.0.2.254
ip dhcp pool LABPool1
 import all
 network 10.0.2.0 255.255.255.0
 default-router 10.0.2.254
 dns-server 8.8.8.8
 domain-name test.co.uk
ip domain name test.co.uk
ip name-server 8.8.8.8
ip cef
no ipv6 cef
username xxxxx secret
controller VDSL 0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0
 switchport access vlan 101
 no ip address
interface FastEthernet1
 switchport access vlan 111
 no ip address
interface FastEthernet2
 no ip address
 shutdown
interface FastEthernet3
 switchport trunk native vlan 111
 switchport trunk allowed vlan 1,10,101,111,1002-1005
 switchport mode trunk
 no ip address
interface Vlan1
 no ip address
 shutdown
interface Vlan101
 ip address XXX.XXX.XXX.76 255.255.255.248
interface Vlan111
 ip address 10.0.2.254 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.73
ip route 172.0.0.0 255.0.0.0 10.0.2.250
line con 0
 session-timeout 10
 login local
line aux 0
 session-timeout 10
 login local
line vty 0 4
 session-timeout 10
 login local
 transport input all
end
VRN-SRRTR01#ping 8.8.8.8 source 10.0.2.254
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.0.2.254
Success rate is 0 percent (0/5)
VRN-SRRTR01#ping 8.8.8.8 source XXX.XXX.XXX.76
Packet sent with a source address of XXX.XXX.XXX.76
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
VRN-SRRTR01#
Many thanks in advance!
Nikolai
2 Accepted Solutions
Brandon Buffin
Is this a lab setup? Does the x.x.x.73 device have a route back to 10.0.2.0? If simulating a connection to an ISP you would normally NAT this traffic so that 10.0.2.0 traffic going out the WAN interface gets translated to the public IP x.x.x.76.
Brandon
Yes your missing NAT agree with that
800 series are routers , with switch modules
6 Replies 6
Brandon Buffin
Brandon
Is this a router or a Layer 3 Switch?
Thanks for your reply Brandon, it is lab setup but i have no control over .73 device as it is ISP owned
I will give it a go!
Kind regards
Nikolai
Worked like a charm, thanks Brandon!
