3750G not saving loaded config to running or startup config.
DC1966
I am writing a new config to my 3750G switch using Putty and a serial cable. When the config has finished loading I get a "Configured from console by console" message. I then end the config load by entering Ctrl Z and am returned to the privileged mode prompt. I then enter "Write" and receive the message building configuration [OK] . If I then try show run or startup I see the old config is still there. What am I doing wrong?
14 Replies 14
Giuseppe Larosa
Hello @DC1966 ,
please post
show version
so that we can see the confreg value
Hope to help
Giuseppe
TTTSWH002#show version
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
TTTSWH002 uptime is 23 hours, 24 minutes
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750G-48TS (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
Processor board ID FCZ1205X09V
Last reset from power-on
4 Virtual Ethernet interfaces
104 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1E:F6:BF:F0:00
Motherboard assembly number : 73-10218-08
Power supply part number : 341-0107-01
Motherboard serial number : FOC11522T92
Power supply serial number : AZS114315Q3
Model revision number : C0
Motherboard revision number : C0
Model number : WS-C3750G-48TS-S
System serial number : FCZ1205X09V
Top Assembly Part Number : 800-26857-02
Top Assembly Revision Number : B0
Version ID : V04
CLEI Code Number : COM7X10ARA
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 2 52 WS-C3750G-48TS 12.2(35)SE5 C3750-IPBASE-M
Configuration register is 0xF
TTTSWH002#
@DC1966 wrote:
2 -rwx 21753 Mar 1 1993 00:32:56 +00:00 newconfig.text
4 -rwx   736 Mar 1 1993 00:02:34 +00:00 vlan.dat
5 -rwx 21948 Mar 2 1993 21:22:01 +00:00 config.text
Something is being written to the "config.text" file because the time stamp is different.
What is "newconfig.text"?
I do not know what Newtonhill.txt is. How can I display it?
      - more flash:newconfig.txt
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
more flash:newconfig.text
DC1966
Leo Laohoo
Post the complete output to the command "sh boot".
DC1966
BOOT path-list : flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Post the complete output to the command "dir".
balaji.bandi
Can you post show version complete and dir output (with out any altering output)
BB
TTTSWH002#dir
Directory of flash:/
3 -rwx 5 Mar 2 1993 21:22:01 +00:00 private-config.text
6 drwx 192 Mar 1 1993 00:08:43 +00:00 c3750-ipbase-mz.122-35.SE5
32514048 bytes total (22840832 bytes free)
TTTSWH002#
Mark Elsen
 - When you try to save the config to startup-config, issue show logging just after doing that  , look for additional info's if any.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
DC1966
posting this to close this question:
When deleting the startup-config any attempt to show it results in a no startup-config message. I assumed the same was true of the running-config and was confusing the default running configuration with my configuration.
Lesson learned.
