3750x 48ts IOS not booting
louis0001
Level 3
Level 3
We have a 3750x 48ts. When I tried to update the IOS with 3750e-universalk9-mz.152-4.E5.bin, it fails to boot.
If I try 3750e-universalk9-mz.152-1.E1.bin, it boots. I've downloaded the newer image a couple of times now and still the same result.... no boot.
This switch is destined for a stack with 152-4.E5.bin so I suspect adding it to a stack will result in the IOS being updated and it failing to boot again.
I know I can downgrade the stack but it's a pain.....
Any ideas why the newer image won't boot?
37 Replies 37
Manoj Padhy
I was not able to see any solution/ fix for the given issue on the post, did you got to know the issue or fix?
I recently tried to upgrade 3705X with same IOS version and got similar error
Had verified the IOS image before the upgrade
switch# verify /md5 flash:c3750e-universalk9-mz.152-4.E6.bin
...........................................................................................Done!
verify /md5 (flash:c3750e-universalk9-mz.152-4.E6.bin) = b4c77931da557bd916c7d04091dca4a8
Background
was trying to upgrade SW - WS-C3750X-48PF-L IOS from "c3750e-universalk9-mz.150-2.SE10.bin"- to "c3750e-universalk9-mz.152-4.E6.bin" but encountered a similar issue.
when logged into the switch via OOB, the switch was in ROMMON mode - tried to boot the switch again with same IOS - "c3750e-universalk9-mz.152-4.E6.bin" but it kept failing, so had to roll back to the old working IOS.
Below are the Logs from the switch when trying to load 15.2(4)E6 and it kept failing
switch: boot
Loading "flash:/c3750euniversalk9mz.152-4.E6.bin"... @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3750e-universalk9-mz.152-4.E6.bin" uncompressed and installed, entry point: 0x3000
executing...
Boot process failed...
switch:
when the switch came online I could not see anything on the device log
I had 2 such switches, one got upgraded without any issue while this one had the above issue
I could notice few Hardware and Version different on both
Device 1 was one which had no issue where as the Device 2 had the issue
Device 1   Device 2
 cisco WS-C3750X-48 (PowerPC405) processor (revision K0) with 262144K bytes of memory.    cisco WS-C3750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
 Model revision number           : K0    Model revision number           : A0
 Motherboard revision number     : A0    Motherboard revision number     : A0
 Model number                    : WS-C3750X-48T-L    Model number                    : WS-C3750X-48PF-L
 Daughterboard assembly number   : 800-32727-03    Daughterboard assembly number   : 800-32727-03
 Top Assembly Part Number        : 800-31326-07    Top Assembly Part Number        : 800-31324-09
 Top Assembly Revision Number    : A0    Top Assembly Revision Number    : B0
 Version ID                      : V04    Version ID                      : V06
 CLEI Code Number                : COMJT00ARD    CLEI Code Number                : CMMPS00DRA
 Hardware Board Revision Number  : 0x04    Hardware Board Revision Number  : 0x05
 Configuration register is 0xF    Configuration register is 0xF
Thank you
Has anyone solved this problem meanwhile?
I have the same isse on Cat3750X-12S with
File "flash:/c3750e-universalk9-mz.152-4.E8.bin" uncompressed and installed, entry point: 0x3000
executing...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
15.0(2)SE11 works fine on this Switch.
Niels
Console into the switch and reboot.
Post the entire boot-up process.
the switch is working fine with 15.0(2) but no 15.2.(4) Image is booting,
Booting via usbflash0 failed also
MD5 checksum is OK
Switch#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 09-Aug-18 05:57 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 1 hour, 20 minutes
System image file is "flash:/c3750e-universalk9-mz.150-2.SE12.bin"
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#boot system flash:/c3750e-universalk9-mz.152-4.E8.bin
Switch(config)#^Z
Switch#wr
Building configuration...
*Jan 2 01:22:06.931: %SYS-5-CONFIG_I: Configured from console by console[OK]
Switch#reload
Proceed with reload? [confirm]
*Jan 2 01:22:13.080: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
Using driver version 3 for media type 2
Base ethernet MAC Address: 74:26:ac:4b:3e:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes : 2097152
mifs[2]: Bytes used : 741376
mifs[2]: Bytes available : 1355776
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 4194304
mifs[3]: Bytes used : 8192
mifs[3]: Bytes available : 4186112
mifs[3]: mifs fsck took 1 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 524288
mifs[4]: Bytes used : 49152
mifs[4]: Bytes available : 475136
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 524288
mifs[5]: Bytes used : 49152
mifs[5]: Bytes available : 475136
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 6 files, 1 directories
mifs[6]: Total bytes : 119144448
mifs[6]: Bytes used : 66535424
mifs[6]: Bytes available : 52609024
mifs[6]: mifs fsck took 32 seconds.
...done Initializing Flash.
done.
Loading "flash:/c3750e-universalk9-mz.152-4.E8.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
executing...
executing...
image.
switch:
With c3750e-universalk9-mz.152-4.E7.bin it it the same
Niels
Post the output to the command "dir".
That's not the problem ...
Switch#dir
Directory of flash:/
2 -rwx 1785 Jan 2 2006 00:03:50 +00:00 config.text
3 -rwx 1914 Jan 2 2006 00:03:50 +00:00 private-config.text
4 -rwx 25891840 Jan 2 2006 00:21:55 +00:00 c3750e-universalk9-mz.152-4.E5.bin
5 -rwx 20440064 Jan 2 2006 09:16:40 +00:00 c3750e-universalk9-mz.150-2.SE12.bin
6 -rwx 20440960 Jan 2 2006 00:03:45 +00:00 c3750e-ipbasek9-mz.150-2.SE12.bin
8 -rwx 25545728 Jan 2 2006 00:02:14 +00:00 c3750e-universalk9-mz.152-4.E8.bin
7 -rwx 3096 Jan 2 2006 00:03:50 +00:00 multiple-fs
119144448 bytes total (26685440 bytes free)
Switch#
Delete two of the BIN files you don't want to use and try again.
That's not the solution, it
this Switch don't want to boot with any 15.2-4 Image ...
executing...
image.
Can the switch boot 15.2(4)E5?
Post the complete output to the command "sh bootvar".
I tested so much, also USB Booting
it's is a bug in the Software or a defective switch
Switch#show boot
BOOT path-list : flash:/c3750e-universalk9-mz.152-4.E5.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
Allow Dev Key : yes
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 524288
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Switch#dir
2 -rwx 25891840 Jan 2 2006 00:08:02 +00:00 c3750e-universalk9-mz.152-4.E5.bin
4 -rwx 1758 Jan 2 2006 00:10:23 +00:00 config.text
5 -rwx 3096 Jan 2 2006 00:10:23 +00:00 multiple-fs
6 -rwx 1914 Jan 2 2006 00:10:23 +00:00 private-config.text
119144448 bytes total (93188096 bytes free)
Switch#reload
*Jan 2 00:10:31.217: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
mifs[6]: 4 files, 1 directories
mifs[6]: Bytes used : 25956352
mifs[6]: Bytes available : 93188096
done.
Loading "flash:/c3750e-universalk9-mz.152-4.E5.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c3750e-universalk9-mz.152-4.E5.bin" uncompressed and installed, entry point: 0x3000
executing...
executing...
image.
switch:
Get the switch to boot 15.0(2)SE and post the complete output to the command "sh version".
Switch#show version
Switch uptime is 2 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision K0) with 524288K bytes of memory.
Processor board ID
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :
Motherboard assembly number :
Motherboard serial number :
Model number : WS-C3750X-12S-S
Daughterboard serial number :
System serial number :
Version ID : V05
CLEI Code Number :
984048K bytes of USB Flash usbflash0 (Read/Write)
Switch Ports Model SW Version SW Image
* 1 18 WS-C3750X-12S 15.0(2)SE12 C3750E-UNIVERSALK9-M
Switch#
I have never seen a behaviour like this before.
However, I want to ask if you can try something ...
1. Download the latest 12.2(55)SE and get the switch to boot this version;
2. After the switch has booted this version, upgrade to 15.2(4)E8 and see if there are any improvements.
after testing with c3750e-ipbasek9-mz.122-55.SE13.bin then
switching to 15.2-4
It was the same,
i don't know what this could be,
maybe defective ...
Did the switch do a micro-code upgrade during the downgrade/upgrade to/from 12.2(55)SE?
