10-19-2017 02:37 PM - edited 03-08-2019 12:25 PM
We have a 3750x 48ts. When I tried to update the IOS with 3750e-universalk9-mz.152-4.E5.bin, it fails to boot.
If I try 3750e-universalk9-mz.152-1.E1.bin, it boots. I've downloaded the newer image a couple of times now and still the same result.... no boot.
This switch is destined for a stack with 152-4.E5.bin so I suspect adding it to a stack will result in the IOS being updated and it failing to boot again.
I know I can downgrade the stack but it's a pain.....
Any ideas why the newer image won't boot?
09-05-2019 12:19 PM
yes - he did
without any error-message
09-06-2019 01:43 AM
09-07-2019 01:48 AM
it is the same, and looks like a bug ...
File "flash:/c3750e-universalk9-mz.152-4.E6.bin" uncompressed and installed, entry point: 0x3000
executing...
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
09-07-2019 02:55 AM
09-08-2019 11:50 AM
bootvar is okay,
15.0(2)SE11 is running
It is not a simple mistake, i have long experience too
09-08-2019 03:37 PM
@ngraupe wrote:
16 Gigabit Ethernet interfaces
You don't happen to have an SM module attached, would you?
09-09-2019 12:29 AM
We do not use SM modules. I also have no access to one
09-09-2019 02:03 AM
