3750X stand alone secondary power supply act as a pool of power
chadreynolds
In a stand alone 3750x switch configuration, can the secondary power supply only act as a redundant power supply (active/standby), or can it become a "pool" of power similar to power sharing mode for StackPower (somewhat active/active)?  I understand there is no stack involved here but I'm curious if this functionality is possible.
Reza Sharifi
You can't combine the power supplies, but both power supplies are active. You can combine the power supplies in bigger chassis like 4500, 6500, etc..
have a look:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/HIGFRU.html
