3750X Upgrade to 15.0
jrmildren
I upgraded one of our new 3750x's to 15.0(2)SE5 from 12.2 and now I am seeing the following message in the log..
Mar 30 01:28:55.015: platform assert failure: hwidb->snmp_if_index == ifIndex: ../src-hulc/src-common/hpm_idbman.c: 1893: hpm_register_idb_with_snmp
Mar 30 01:28:55.015: -Traceback= 4FFA04z 206281Cz 21F9718z 21FB8DCz 21FBD64z 22056E0z 21DB598z 206490Cz 1C521ACz 1C5236Cz 1C52488z 50DFA4z 50E1E4z 26D8CF8z 26D344Cz
Has anyone seen this message and know if we should be concerned?  I am not sure if it's just something weird with snmp moving to the 15.0 code from 12.2.
Leo Laohoo
My testing of version 15.0(2)SE5 lasted for about 15 minutes.  And the entire time was attempting to ROLL BACK.   When I loaded this version on a 3560, the CPU spiked that I lost connectivity (remotely and console).  I will NEVER recommend any sane person to use 15.0(2)SE version except for 15.0(2)SE4.
For 3560/G/E/X and 3750/G/E/X, I will recommend 12.2(55)SE9 as one of the most stable codes Cisco's ever published.  For 3560G/E/X and 3750G/E/X (with 32 mb flash), you can also try 15.0(2)SE4.
PS:  Don't be tempted to use 15.2(1)E train either.  It's the worst IOS train I've ever seen.
Lee Valentin
Those traceback errors should be addressed immediately.
If you are using Cisco Prime, you could be getting hammered via SNMP so maybe you can temporarily do a 'no snmp-server' and see if the messages go away.
Another issue I encountered was a memory leak caused by Auth manager on this IOS version, and it could be a bug: CSCub85948 (Memory leak caused by CDP, LLDP or DHCP traffic).
The workaround listed on this bug is the following:
Configure the following:
no macro auto monitor
device-sensor filter-spec dhcp exclude all
device-sensor filter-spec lldp exclude all
device-sensor filter-spec cdp exclude all
Not saying that either are the fix but this helped and it is best you get TAC involved to assist.
Good luck
