N7K - powered-dn module status
ramikamel911
Hi guys,
Suddenly, one of the modules under 7K switch gave red alarm.
Following are the show module:
#show module
Mod  Ports  Module-Type                         Model              Status
4    0      10 Gbps Ethernet Module                                powered-dn
Mod  Power-Status  Reason
4    powered-dn     Unable to power up card (Power_OK not set)
Mod  Sw              Hw
1    6.2(6)          3.0
3    6.2(6)          1.0
Any common issue for that?
Regards.
Jose Solano
Level 4
Level 4
Please try this.
1. Set on config t the diagnostic bootup level complete
2. Reseat module 4
3. show diagnostic result module 4
4. show module
If you still face the same issue after reseating it then RMA the module. Also check the available power on the switch and the minimum version required for the module to run fine.
There is no "Reseat module 4" command.
  He means to pull the card out and then reseat it into the backplane..
