04-13-2010 07:25 AM - edited 03-06-2019 10:35 AM
I have a Cisco 3825 router with a switchport module NM-ESW-16. I am using the switchport as a L2 switch with no problems, with the fastethernet ports configured that way, can ping etc on that module. What I can not do is get out of that module, I have another router connected. I created a VLAN (vlan 100) that has right now 1 port assigned but did have more. I can not ping from the router the workstation and cannot do vice versa. Below is my running config... just a note I do not start adding portfast, stp etc until I am sure it works that is why it is so basic right now.
current configuration : 3714 bytes
version 12.4
service password-encryption
hostname XXXXXX
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no network-clock-participate wic 1
ip cef
no ip domain lookup
ip domain name XXXXXXXXXXXXXXXXXX
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
username XXXXXXXX privilege 15 password 7 XXXXXXXXXXXXXXXX
cem 2/0/0
payload-size 32
cem 2/1/0
payload-size 32
cem 2/2/0
payload-size 32
cem 2/3/0
payload-size 32
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
ip address 205.10.182.254 255.255.255.255
interface GigabitEthernet0/0
ip address 205.10.182.249 255.255.255.252
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Serial0/1/0
no ip address
shutdown
clock rate 2016000
interface Serial0/1/1
no ip address
shutdown
clock rate 2016000
interface Serial0/1/2
no ip address
shutdown
clock rate 2016000
interface Serial0/1/3
no ip address
shutdown
clock rate 2016000
interface FastEthernet1/0
switchport access vlan 100
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
interface Vlan100
ip address 205.10.182.1 255.255.255.240
router ospf 100
log-adjacency-changes
network 205.10.182.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 5 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 5 0
transport input ssh
scheduler allocate 20000 1000
end
Solved! Go to Solution.
04-13-2010 07:57 AM
Hi Adam,
If you can, it might be an idea to remove the HWIC-4ESW.
This article (http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_qas0900aecd802a9470_ps5854_Products_Q_and_A_Item.html) suggests that the HWIC-ESW and NM-ESW need to be connected externally for them to work correctly in the same chassis.
Kevin
04-13-2010 07:37 AM
Can you share the Network configaurtion and other router config.
Also shut down the interface vlan t1 in the pased config.
04-13-2010 07:41 AM
what do you mean by network config, also the other router is not in the loop now. I am just trying to get from the switchport module on router A to router A.
04-13-2010 07:46 AM
Hi Adam,
Do you have any other switch modules in the router? If so, are they connected to each other?
Kevin
04-13-2010 07:53 AM
no there is a NM-CEM-4SER and a HWIC-4esw which neither are configured to my knowledge and there are no cabling between them.
04-13-2010 07:57 AM
Hi Adam,
Kevin
04-13-2010 08:05 AM
Ok so I pulled the HWIC-4 esw card out...and it works. Now I am completly lost. Why would the two cards plugged in not work if they are not configured or cabled together or anything?
I think i am understanding it more after reading. What I am understanding is it needs to be stacked? So I have to view the switch module as a switch and basically do a router on a stick concept?
04-13-2010 08:42 AM
Hi Andy,
I think that the ISR's only have one internal link to a switch module. In you case it looks like the HWIC one was using it and not the NM-ESW.
Kevin
(Thanks for the rating)
