3850 - after upgrade APs disabled
kpanduric
The switch stack running XE software version 03.03.02E has been upgraded to version 03.07.01E.
After the stack came up the WLAN is inoperable, the 2.4G and 5G bands on APs seem to be disabled:
3850#sh ap dot11 24ghz summary
AP Name                           MAC Address     Slot  Admin State  Oper State  Channel        Width  TxPwr
APd072.dcac.384f                  00e1.6da2.50d0     0  Enabled      Down        1*                20    2(*)
AP88f0.31e3.c5c7                  381c.1a2f.5270     0  Enabled      Down        11*               20    2(*)
Found out that it can be manually enabled:
3850(config)#no ap dot11 24ghz shutdown
APd072.dcac.384f                  00e1.6da2.50d0     0  Enabled      Up          1*                20    2(*)
AP88f0.31e3.c5c7                  381c.1a2f.5270     0  Enabled      Up          11*               20    2(*)
Comparing the configurations before and after the changes have been made, I  see no difference. Where is that part of config  stored, is it persistent, what if the switch reloads?
Mark Malone
Looks like a Bug running 3.7.1, 3650s and 3850s run the same code
https://tools.cisco.com/bugsearch/bug/CSCut44062
