Catalyst 2960 not transmitting any data.
Samrat Bose
Hi Experts, I have a home switch Catalyst 2960 for my home lab. I'm using this switch since 2014 July, everything was working fine, suddenly, since yesterday, it started creating problem. Using this switch, now I am not able to connect outside anywhere. I've pasted the running-config and flash details, can anybody, please help me out on this issue??
S1#show running-config
Building configuration...
Current configuration : 6138 bytes
version 12.2
no service pad
hostname S1
boot-start-marker
boot-end-marker
username administrator privilege 15 secret 5 $1$ucJF$CJkWl0P.o2YgD1selNXq31
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization config-commands
aaa authorization exec default local
aaa session-id common
clock timezone BST 5 30
system mtu routing 1500
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.99.28 192.168.99.30
ip dhcp pool Group-A
   network 192.168.99.0 255.255.255.224
   default-router 192.168.99.1
   dns-server 192.168.2.254 4.2.2.2
ip dhcp pool admin_asst
   host 192.168.99.27 255.255.255.224
   client-identifier 0154.bef7.3722.fb
ip domain-name test.local
ip name-server 192.168.2.254
ip name-server 192.168.3.254
ip name-server 8.8.8.8
ip name-server 202.129.196.3
crypto pki trustpoint TP-self-signed-3179159040
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3179159040
 revocation-check none
 rsakeypair TP-self-signed-3179159040
crypto pki certificate chain TP-self-signed-3179159040
 certificate self-signed 01
  30820250 308201B9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313739 31353930 3430301E 170D3134 30373134 30373132
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31373931
  35393034 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C1FA F8807A87 1EA00E80 A250F44A 4792C219 5F0118BA F06278BE 83CB9D3A
  17B80337 09406976 49277C10 EC5F870E A920271D FAB6BEE4 2A3E0AEF 89299D4F
  CE02D476 F0734170 FDED2CDA FEC8CF9B C3D6CCFA 1B9B0C4D 509637D0 95D2B3B9
  948838C8 47F3DC72 B767E418 64091629 6CABA34E 3204E8CA 8BF2FCEA 9557C574
  14230203 010001A3 78307630 0F060355 1D130101 FF040530 030101FF 30230603
  551D1104 1C301A82 1853312E 72767363 6C6F7564 2E727673 6361732E 61632E69
  6E301F06 03551D23 04183016 8014A280 A742B1ED F9BEB96F 62DC96C6 E14DC168
  702D301D 0603551D 0E041604 14A280A7 42B1EDF9 BEB96F62 DC96C6E1 4DC16870
  2D300D06 092A8648 86F70D01 01040500 03818100 7CCEBDA7 5EDBDF67 D7C51A16
  00F926CC 5E993FA7 31950A75 59F7DBE0 2B822EE4 FD1F4433 BCD0E443 E79B5EF3
  0BF0A83B 8FA4F8A2 758712CA 13CCC8C2 5BE5847D AB107D6B 21FFA5F0 F502F7C0
  E874422F 4BD6224D 7EBA1594 6F0F958A 48429600 7A4A8C7D 7897989D C40EC38B
  43842B68 769C8957 5855E82E E74EE75C 9888E36A
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
lldp run
interface FastEthernet0/1
 switchport mode access
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
 ip address 192.168.99.28 255.255.255.224
 no ip route-cache
ip default-gateway 192.168.99.1
ip http server
ip http authentication aaa
ip http secure-server
control-plane
banner exec ^C
You are about to execute a instruction inside this device.^C
banner login ^C
You are logging in S1 ^C
line con 0
 logging synchronous
line vty 0 4
 logging synchronous
line vty 5 15
 logging synchronous
end
S1#show flash
Directory of flash:/
    2  -rwx         564   Mar 1 1993 07:15:54 +05:30  vlan.dat
    3  -rwx        5482   Mar 1 1993 05:57:15 +05:30  private-config.text
    4  -rwx         156   Mar 1 1993 07:41:10 +05:30  express_setup.debug
    5  drwx         512   Mar 1 1993 05:42:39 +05:30  c2960-lanlitek9-mz.122-50.SE5
  560  -rwx        3096   Mar 1 1993 05:57:15 +05:30  multiple-fs
  561  -rwx        4762   Mar 1 1993 05:57:15 +05:30  config.text
27998208 bytes total (16777728 bytes free)
was off few days heres the link if you still need it
https://software.cisco.com/download/release.html?mdfid=282644796&catid=268438038&rellifecycle=ED&release=12.2.50-SE5&softwareid=280805680&sortparam=
9 Replies 9
Mark Malone
Can you ping your default gateway ? where does traffic stop when you run a trace from your pc
No Mark, I cannot ping to the switch on its vlan 1 and also cannot ping from the switch (after logging in using console) to the default-gateway.
Just so i have this right vlan 1 is up/up and even when you are consoled in it still will not ping the local vlan 1 ip address.
Are you getting anything in the show logs ? I presume you have connected directly to the router and have no issues with that reaching the internet just to completely isolate the switch as the issue
Option to reset the switch
http://notthenetwork.me/blog/2013/05/28/reset-a-cisco-2960-switch-to-factory-default-settings/
Yes, I have a direct connection to my router. When I connect my PC to the router, internet connection is absolutely smooth, but since yesterday, no internet connection is reaching to my PC crossing the switch. In show logs no output is present.
I guess, I have to reset it to factory default.
Before doing a full reset , make sure vlan 1 is up/up and can be pinged from the console even if the switch cant pass traffic for some reason it should be able to ping its owjn interfaces when there up
You could save the config to txt file, delete the contents of flash(leaving just the ios image)
reboot the switch and re-apply the config see if that helps , have you tried a reboot already just in case its locked up
if that does not work you could re-image it theres a safe harbour version available for that switch SE10 from February
Hi Mark, can you please give me the link from where to get the safe harbour version SE10 for this switch?
have you tried changing port on which the router is connected.
Hitesh
Yes, Hitesh, I tried that too, but no change. I'll have to reset it today.
