3850 flash error
kirkchris01
Frequent Visitor
Frequent Visitor
I have a 3850 that cannot seem to boot up. I tried booting from USB. I tried booting with SWITCH_IGNORE_STARTUP_CFG. It gets stuck every time with the error below when it tries to launch linux kernel. I believe one problem is that the flash is full but I don't seem to have permission to delete any files. What I remember from Linux, -rw means it is a file that I should be able to read or write. This switch is just stuck with the error below and I can't seem to affect anything.
switch: dir flash:
Directory of flash:/
23233 drwx 4096 .
2 drwx 4096 ..
23234 -rw- 2097152 nvram_config
23235 -rw- 2097152 nvram_config_bkup
23236 -rw- 83284288 cat3k_caa-base.SPA.03.06.09E.pkg
23237 -rw- 3949504 cat3k_caa-drivers.SPA.03.06.09E.pkg
23238 -rw- 33805552 cat3k_caa-infra.SPA.03.06.09E.pkg
23239 -rw- 42815044 cat3k_caa-iosd-universalk9.SPA.152-2.E9.pkg
23240 -rw- 28460176 cat3k_caa-platform.SPA.03.06.09E.pkg
23241 -rw- 112671812 cat3k_caa-wcm.SPA.10.2.190.0.pkg
61954 -rw- 4737 packages.conf
38721 drwx 4096 dc_profile_dir
46470 -rw- 35 pnp-tech-time
46471 -rw- 83893 pnp-tech-discovery-summary
46468 -rw- 65301 memleak.tcl
46469 drwx 4096 .installer
61953 -rw- 1237 packages.conf.00-
23242 drwx 4096 core
77444 -rw- 15950464 cat3k_caa-guestshell.16.03.06.SPA.pkg
77445 -rw- 22302593 cat3k_caa-rpbase.16.03.06.SPA.pkg
77446 -rw- 265124472 cat3k_caa-rpcore.16.03.06.SPA.pkg
7745 -rw- 9095808 cat3k_caa-srdriver.16.03.06.SPA.pkg
7746 -rw- 211675764 cat3k_caa-wcm.16.03.06.SPA.pkg
7747 -rw- 13423228 cat3k_caa-webui.16.03.06.SPA.pkg
61955 -rw- 185 bootloader_evt_handle.log
30977 drwx 4096 .prst_sync
46467 drwx 4096 .rollback_timer
54210 drwx 4096 gs_script
46472 -rw- 11008 vlan.dat
46473 -rw- 11288 -Mar-28-08-55-22.354-PST-0
46474 -rw- 58834 -Mar-28-08-58-20.583-PST-1
46475 -rw- 59820 -Mar-28-08-58-48.440-PST-2
46476 -rw- 66293 -Jun-12-15-48-28.483-PST-80
46477 -rw- 68198 -Jun-13-13-05-49.892-PST-81
46478 -rw- 68092 -Jul-10-21-47-37.831-PST-0
46479 -rw- 61454 -Jun--9-13-05-40.707-PST-75
46480 -rw- 66173 -Jun-10-08-14-06.883-PST-76
46481 -rw- 68078 -Jun-10-13-05-42.747-PST-77
46482 -rw- 68078 -Jun-11-13-05-46.303-PST-78
46483 -rw- 68078 -Jun-12-13-05-48.204-PST-79
770473984 bytes available (877420544 bytes used)
switch: delete flash:-Mar-28-08-55-22.354-PST-0
Are you sure you want to delete "flash:-Mar-28-08-55-22.354-PST-0" (y/n)?y
File "flash:-Mar-28-08-55-22.354-PST-0" not deleted -- read only file system
This is where the boot process gets locked up:
### Launching Linux Kernel (flags = 0x5)
ata1.00: cmd ca/00:06:47:a5:07/00:00:00:00:00/e0 tag 0 dma 3072 out
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
ata1.00: status: { DRDY }
6 Replies 6
Hello
Try the following and see if it boots
boot flash:packages.conf
if successful then change boot variable on the switch to point to that file and save changes
no boot system
boot system flash:packages.conf
Kind Regards
Paul
That's a no-go. It got stuck at the same point.
Look at this thread may help you to resolve the issue :
https://community.cisco.com/t5/switching/3850-boot-failure/td-p/3177293
BB
Have you tired a different iOS version?
Kind Regards
Paul
Mark Elsen
 - Try fsck flash:  (include the double column).
    M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
I want to see the COMPLETE output when the switch is rebooting.
