03-18-2018 07:20 AM - edited 03-08-2019 02:18 PM
In our Project there Bosch camera in one switch 3850 POE+ the Out door Camera are not taking Power
But when it is connected to POE++ it is taking Power.
I had Check the data sheets of Camera 30 watts.
Please advice.
03-18-2018 07:27 AM
Do you have more devices requesting PoE on the switch, the switches have limit of Watts to provision.
03-18-2018 07:33 AM
Thanks Julio Moisa,
They are Four Switches out which one Switch Camera are not working tomorrow I am going to site which today coordinate via phone.
please advice what need to be check for trouble shooting
03-18-2018 07:38 AM
There are different models of Cisco 3850 switches, some of them support UPoE, if Im not wrong it could provide until 49 watts per port. Now You must identify the watts required by the Cam to turn on. Also you can use: show power inline, to verify the watts supported by port.
Please keep us posted.
03-21-2018 01:39 PM
when I visted the site the out door PTZ camera need the external power supply when they connected the power supply the switch port become up
03-21-2018 06:01 PM
Hold on, this doesn't make any sense.
Does the camera support PoE or not?
03-21-2018 06:43 PM
well apparently it didnt. LOL
03-18-2018 02:30 PM
03-18-2018 10:19 PM
How long is the cable between Cam and switch?
03-19-2018 02:35 AM - edited 03-19-2018 02:37 AM
Hello Syed,
As per the Cisco 3850 datasheet, the standard POE (802.af) supplies 15.4 watts per port on the switch and for the POE+ (802.at) provides 30 watts per port.
Refer to the datasheet and check table 6:
Since you have mentioned that it is taking power on POE+ port this suggests that the standard POE port didn't supply enough power for the camera to work.
You can figure out the power consumption using "sh power inline <PORT>" and "sh interface <PORT>"as suggested by Leo as well.Remember the switches have limited power that can be supplied to the devices requiring POE.
Hope it helps.
Don't forget to rate.
