3850 Switch - QOS
Craig Le-Butt
HI
We've just purchased 3850 switch part of a wireless upgrade, but we are usign 8500 wlc.
Want to use the 3580 just as a edge switch without the wlc as we didn't purchase the licences.
Using our exsiting 3750x template haing issues with the QOS settings
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input cos-map queue 2 threshold 1 3
mls qos srr-queue input dscp-map queue 2 threshold 1 24
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 3 3
mls qos srr-queue output cos-map queue 3 threshold 1 1
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 6 7
mls qos queue-set output 2 threshold 2 3200 3200 100 3200
mls qos queue-set output 2 buffers 10 70 10 10
mls qos
any help would be apprieicated in pointing to right direction.
Have been looking for last couple of days.
cheers
Robert Falconer
The settings in the 3650 and 3850 follow the XE QoS design. If you do a quick search, you'll see that they now use the MQC framework.
Ton V Engelen
Level 3
Level 3
this might help (as we moved from 3750 to 3850 switches, we had to rebuild qos).
The basic idea is something like this
Class-maps:
class-map match-any CM_VOIP
match dscp ef
class-map match-any CM_SIGNALING
match ip dscp cs3
match ip dscp af31
class-map match-any VC_VIDEO
match dscp af41
Policy map for the uplink:
policy-map UPLINK-OUT
class CM_VOIP
priority level 1 percent 10 (this is the high priority queue)
police cir percent 10 conform-action transmit exceed-action drop
class CM_SIGNALING
priority level 2 percent 5 (low priority queue)
police cir percent 5 conform-action transmit exceed-action drop
class VC_VIDEO
bandwidth remaining percent 10
class class-default
bandwidth remaining percent 75
Uplink config:
Interface Gi1/1/1
Service-policy output UPLINK-OUT
This way you can build your qos policies. You can tune anyway you like / configure more traffic types and/or confighure policies for access ports
HI
thanks for this, did you have to do any changes on your distribution to get this to work?
What would be interesting if I could see your original QOS so I could better understand it, if that is OK?
cheers
1. no, we have a collapsed core, 6509 switches. For us no need to change anything there as far as qos is concerned compared to the 3750 config.
2. i do not have any backups of the old configs anymore. All gone. Sorry bout that.
But if you need any help with this let me know.
