3850X Link Aggregation Issue
Furrukh Rao
I am trying to convert Access Ports into Trunk Ports on C3850X 10G MM SFP but neither I cant change them nor I can assign a Native VLAN.
The links are not physically up which means the other side is not connected yet does that make any difference ?
Configuration :
interface TenGigabitEthernet1/0/6
description *** VxINF09 Vnic 0 ***
switchport trunk native vlan 120
switchport mode trunk
ip flow monitor ForeScoutMonitor sampler ForeScoutSampler input
ip flow monitor ForeScoutMonitor-Output sampler ForeScoutSampler output
snmp trap mac-notification change added
interface TenGigabitEthernet1/0/7
description *** VxINF09 Vnic 1 ***
switchport mode dot1q-tunnel
interface TenGigabitEthernet1/0/8
description *** VxINF09 Vnic 2 ***
interface TenGigabitEthernet1/0/9
description *** VxINF09 Vnic 3 ***
Any suggestion ?
Reza Sharifi
The below config is correct. Just make all the other ports the same as this one and delete "switchport mode dot1q-tunnel"
Durood,
It got solved in live environment because they were not connected to Dell Servers at the moment.
Baratheon
Sorry, let me ask the question too.
The problem encountered in configuring the Trunk+Etherchannel group is that PC1 and PC2 are on different network segments, but I want PC1 to be able to successfully interconnect with PC2 (ping is successful), how should I configure it?
I would really appreciate your help!
