4331 ISR with Switch Module
Andy Guley
Level 3
Level 3
I currently run 2911 routers with the integrated switch module.  I am going to be migrating to 4331 with the integrated switch module.  I am having some issues figuring out how to create VLAN's and SVI's.
Router(config)#vlan ?
  accounting  VLAN accounting configuration
Router(config)#int vlan 90
% Invalid input detected at '^' marker.
Can you not create VLAN's and SVI's to use the backplane like you used to be able to on the 2911's?  I cant find any good documentation on Cisco's site one way or another.
acampbell
Hi Andy,
Looks like its getting harder to config on 4000s .
see this links from a brother in arms
https://supportforums.cisco.com/discussion/12470821/configuring-sm-x-layer-23-etherswitch-service-module-4331-router
Alex
Regards, Alex. Please rate useful posts.
acampbell
Hi Andy,
Alex
I talked with TAC today.  They advised that the code has to be Cisco IOS XE Software, Version 03.15 and above.
If its 03.15 and above you can run the commands.  I upgraded the router and I know how the ability to run the commands.
