4500-X - CPU process K5CpuMan Review
a.auvinet
Hi Everybody,
I have 2 4500-x in VSS mode.
The CPU core 1 is 92  79 and 67 %
 But when i do sh processes cpu sorted
          5Sec             1Min           5Min                TTY Process
       55.36              53.52           51.02 0           iosd
       47.64              43.59           41.53 0           iosd
       7.71                9.92             9.50 0             iosd.fastpath
.      0.00                0.00             0.00 0             CMI Thread
       0.00                0.01             0.02                iosd.monitor
       0.00                0.00             0.00                iosd.aux
       29.55              32.33           30.66              Cat4k Mgmt LoPri
       18.88              4.11             2.99                SNMP ENGINE
       6.33                4.11             4.44                Cat4k Mgmt HiPri
        3.55               0.77             0.55                IP SNMP
       2.11                2.33             2.33                Spanning Tree
       2.00                1.00             0.88                 IP Input
sh platform health :
K5CpuMan Review              30.00           26.96           30  50 100 500 28 33 28 9365:00
K5ForerunnerPacketMa       2.00           10.10            4 28 100 500 9 13 14 2690:03
Do you kow what is  the process K5ForerunnerPacketMa ?
Why when I do "sh processes cpu sorted", the sum of process see less than 92% ??
Cdlt,
10 Replies 10
Leo Laohoo
IOSd means the switch has link(s) that are being overutilized.  Check each interface and determine which one has the highest amount of "output drops".
Ok.
I done "clear counter" on all interfaces.
I will see in one hour  if 4500-x has one or more interfaces with "output drops".
There aren't of "output drop" on interfaces.
sw-4500x-vss#sh interfaces  | inc Input queue
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
What firmware is the chassis running on?
After the output above, is the CPU still high?
Firmware is  Version 03.08.01.E RELEASE SOFTWARE (fc2)
I juste did clear counter, yes the CPU still high.
Core 0: CPU utilization for five seconds: 27%; one minute: 24%; five minutes: 24%
Core 1: CPU utilization for five seconds: 83%; one minute: 86%; five minutes: 80%
PID     Runtime(ms) Invoked   uSecs  5Sec 1Min 5Min TTY   Process5028 2692927 270561741 425 54.1 53.5 51.4 0 iosd
I did "sh platform health"
                                       %CPU %CPU RunTimeMax Priority Average %CPU Total
                                          Target Actual Target Actual Fg Bg 5Sec Min Hour CPU
K5CpuMan Review           30.00     23.13     30 52 100 500 20 28 27 9746:44
K5ForerunnerPacketMa   2.00       8.35        4 28 100 500 6 10 13 2879:53
And " show processes cpu detailed process iosd sorted | excl 0.00"
sw-4500x-vss#show processes cpu detailed process iosd sorted | excl 0.00
Core 0: CPU utilization for five seconds: 17%; one minute: 22%; five minutes: 23%
Core 1: CPU utilization for five seconds: 87%; one minute: 82%; five minutes: 75%
PID T C TID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5028 L 3386292 2707280 425 51.84 52.11 49.08 0 iosd
5028 L 1 5028 1433867 3548698 0 44.40 42.67 40.07 0 iosd
5028 L 0 7274 876692 3438413 0 7.43 9.44 9.01 0 iosd.fastpath
91 I 88296 8760108 0 21.99 31.77 29.22 0 Cat4k Mgmt LoPri
422 I 3674054 9154685 0 16.88 3.55 3.44 0 SNMP ENGINE
90 I 3121536 1910472 0 7.11 4.33 5.99 0 Cat4k Mgmt HiPri
207 I 3247279 3556200 0 2.44 2.55 2.33 0 Spanning Tree
423 I 2209834 1608144 0 1.55 0.55 0.55 0 IP SNMP
198 I 1664398 4310315 0 1.00 0.88 0.77 0 IP Input
29 I 2132043 1690170 0 0.44 0.66 0.77 0 ARP Input
221 I 2170402 1223383 0 0.33 0.44 0.33 0 ADJ background
213 I 2083084 1988174 0 0.33 0.22 0.22 0 BGP I/O
421 I 669784 8068916 0 0.33 0.11 0.11 0 PDU DISPATCHER
230 I 705852 3410586 0 0.22 0.11 0.11 0 TCP Timer
171 I 1861517 2139331 0 0.11 0.11 0.22 0 Tunnel IOSd shim DB
When you remote into the switch, is the response time sluggish or is it snappy?
The reponse time is very good.
No problem.
not sluggish  or snappy.
Perhaps I worry for nothing
I agree.  Could be "cosmetic".
Just keep monitoring.
