07-30-2014 01:50 PM - edited 03-07-2019 08:13 PM
Hello Everyone,
i am in the process of building our network in our new location , we have 3 floors with around 200 users in each floor, our current topology is as follows:
10 cisco sg-300 as access switches with 1 X 2960XR as a distribution in each floor
each 2960XR will be connected through 2 X 10Gbe fiber uplinks to the core switch thats a total of 5 fiber 10 Gbe uplinks.
in our server room we have 3 dell R720 servers , 1 EMC storage unit, the servers and the storage will be connected through 2 X 10Gbe copper connections for a total of 10G copper conenctions.
we are in a choice between the 4500-X and nexus 3064-32T as a core switch , if you can recommend which one to use as we will mix 1G/10G fiber/copper connections , no vlan routing to be done on the core switch. i have read a pretty good reviews on the 4500-x but i am not sure about the 3064.
would you recommend any other options to this design.
thanks in advance
09-22-2014 01:01 PM
What switch have you decided on?
01-16-2015 03:39 PM
Sorry for the delay , i have bought the 3064-32T , it seemed more cost effective as the transceivers are so expensive and it has more ports too.
10-13-2015 11:43 AM
I am trying to make the same decision. Ar you happy going with the Nexus?
