10-18-2018 07:57 AM - edited 03-08-2019 04:24 PM
I am running 3.4.5 & need to up grade 3.5.3 what are option I have. ROM is compatible with 3.5.3E
ROM: 15.0(1r)SG10
Current version - 03.04.05.SG
attached information is confusing, please help
& other option 2 without outage
@@@ is it possible
show running-config,
show redundancy state
Switch# show redundancy
Load IOS on both SUP
copy ftp bootflash:
copy bootflash: slavebootflash:
boot system flash bootflash:new_image
4500# show bootvar
#(CONFIG T)#config-register 0x2102
# wr mem
#redundancy reload peer
wait & check active standby hot & repeat
#redundancy force-switchover
Solved! Go to Solution.
10-19-2018 10:31 AM
When doing a major upgrade like this, ISSU will not work. Actually, ISSU does not work most of the time as expected and can cause more outage than you originally planned for. Have a maintenance window, load the new IOS, set the boot parameters, save and reboot both chassis. The 4500x take about 5 to 6 minute to fully boot.
10-18-2018 08:53 PM
Look at the release date for 3.5.3. It is 09 May 2014.
TAC would not be that stupid to recommend a firmware that is >4 years old.
I'd recommend the latest 3.6.X.
10-19-2018 05:24 AM - edited 10-19-2018 05:25 AM
Thanks Leo,
can you guide how to go 3.6.X. without outage from 3.5.4?
10-19-2018 06:44 AM
10-19-2018 08:29 AM
Thanks - it was wrong attachments. I just updated
10-19-2018 10:31 AM
10-19-2018 10:32 AM
10-19-2018 10:39 AM
If you plan it well (load the IOS ahead of time and verify it) the entire window should not take more than 30 minutes.
If you have a service contract, you also may want to open a support ticket so, a tac engineer can be online during the process.
Good Luck!
