4507 stuck in rmon
Charles Hill
4507 is stuck in rmon.  Here is the output from the bootup.
etermining FTL format status of volume.
Block 506 has invalid FTL signature.
Block 506 will be reformatted.
Volume is FTL formatted.
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
Rom Monitor Program Version 12.2(44r)SG3
CPU Rev: 2.0, Board Rev: 6, Board Type: 10, CPLD Jawa Rev: 20
Chassis: WS-C4507R-E
Front Panel Phy is Bcm5482s
Got Mac Address: 00:25:84:1d:c0:17
MAC Address  : 00-25-84-1d-c0-17
Ip Address   : Not set.
Netmask      : Not set.
Gateway      : Not set.
TftpServer   : Not set.
rommon 1 >confreg 2102
usage: confreg
rommon 2 >
glen.grant
Try boot bootflash: to see if it will continue to load.  If you use 0x2102 for the register then you must have a boot statement  pointing to the image .
Hi ,
Try "boot"
Did you change the config-register or delete a file?
Dan
glen.grant
The Configuration registry showed 0 and 40 at next reload.  Is this the reason for the bootup in rmon?
boot bootflash: started the switch without the startup.  I did a copy  start run to restore service.  The config-registry showed 0 and 40 at  next reload.  I changed it to 2102.  I'll reload after hours to verify  it boots up ok.  Any ideas why my registry would show 0 and 40 at next  reload?  Other than someone manually changing it...
Here is my boot statement:
boot system bootflash:/cat4500e-ipbasek9-mz.122-53.SG1.bin
Here is the dir:
Directory of bootflash:/
    6  -rw-    21868675  Jul 29 2009 03:17:54 -05:00  cat4500e-ipbasek9-mz.122-5
0.SG2.bin
    7  -rw-    24462212  Apr 13 2010 09:16:16 -04:00  cat4500e-ipbasek9-mz.122-5
3.SG1.bin
131436544 bytes total (77631488 bytes free)
  Get rid of the forward slash /   that is right before the imagename , not supposed to be there and may keep it from booting. Besides that it looks good and should boot ok once that is removed.
