4507RE - Input Error & CRC
Zaid Farooqui
we recently started to have a problem in on of the department (DeptB) which has 3x3750E stacked switches with X2-LRM (10G) module on port TG3/0/1 .
this connects to the data center's core switch 4507RE's X2-LRM module on port TG2/3.
on checking ping from core to the deptB stack is very bad on default ping size as well as on max ping size, the same test for deptA is successful even with max size of 18024bytes...
DC_Core#ping 172.16.0.3 size 18024 repeat 1000
Sending 1000, 18024-byte ICMP Echos to 172.16.0.3, timeout is 2 seconds:
Success rate is 17 percent (12/70), round-trip min/avg/max = 8/9/12 ms
[DATA CEN   -----------------------(10G Fiber)--------------------[DEPT B - 3x3750Estack]
TER 4507RE] -----------------------10G Fiber)--------------------[DEPT A - 3x3750Estack]
i can see Input Error and CRC error on the interface of the 4507 switch's port 2/3 which connects to the DeptB stack of 3750E ,
where as the DeptB 3750E switches does not have any error on it.
DC_Core#sh int tenGigabitEthernet 2/3
TenGigabitEthernet2/3 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet Port, address is 1cdf.0f7e.22e9 (bia 1cdf.0f7e.22e9)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
     reliability 254/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-LRM
  input flow-control is on, output flow-control is on
  Last input 00:00:03, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 43000 bits/sec, 5 packets/sec
  5 minute output rate 107000 bits/sec, 20 packets/sec
     61405553 packets input, 22086233035 bytes, 0 no buffer
     Received 1794570 broadcasts (832848 multicasts)
     943822 input errors, 943822 CRC, 0 frame, 0 overrun, 0 ignored
     115639393 packets output, 95074403915 bytes, 0 underruns
     0 lost carrier, 0 no carrier
DC_Core#
is this a fiber cable or X2 module problem at the core switch side ???
Richard Burts
My guess is that it is a fiber problem, though it is possible that it is a problem on the card. Do you have another port available on the 4507 where you might (temporarily as a test) move the connection. If the problem moves to the new port then it points to a fiber problem and if the problem stays on the old port then it points to a problem with the card.
Rick
Rick
hi Rick,
i was testing the same..
on the core switch side i swapped fiber patch cords between Dept A & B's modules..
means  pactch cord 1 initially on module 2/2  for Dept A  is now on module 2/3
and patch cord 2 initially on module 2/3 for Dept B is now on module 2/2
the problem from core to the same Dept B stack  172.16.0.3 remains the same..
i can see the crc errors on module 2/2 now..
so this means that both X2-LRm modules are OK at the data center side.
could it be that the X2-LRM on the Dept B stack is going faulty ?
i will also replace the fiber patch cord..
from the data center side i swapped the modules and the patch cords one by one..
the module and patch cord working on dept A are now on Dept B's place but the error remains the same..
this means that its gotta be from the 3750's side..  either the fiber or the module..
is there no way to test this from the switch it self ? like check the health state of the module ? so we can narrow it down to just the patch cord there.
