RSTP question...
jimmysands73_2
Level 9
Level 9
With RSTP, my slide says that its portfast (among other things) is building into RSTP.  I dont understand that statement, shouldnt we still have to use the spanning-tree portfast for the sw to know if its an edge port or not?
Thank you
cadet alain
Yes you're right on Ciswo switches you have to configure Portfast for edge ports.
Regards.
Alain.
jimmysands73_2
Level 9
Level 9
I meant to say :
With RSTP, my slide says that its portfast (among other things) is built into RSTP.
cadet alain
Regards.
Alain.
