6506-E single SUP 720 replacement steps
MFLauder
I currently have a 6506-E with a single SUP 720 as one of my distributions for access switches and last night I had an issue with a TM_DATA_PARITY_ERROR and sent this SUP into ROMMON mode. Our after market support stated this could be an environmental issue that caused this but this switch has been running for years in the same closet and I'm not aware of any environmental changes.
I'm monitoring the SUP to see if the occurs again but I was curious on how to swap the current SUP with a replacement if I have to go this route. If I have to swap I would most likely get the same mode SUP 720. Would I just need to remove the old SUP and put the new one in along with the old flash cards and be good to go?
Thank you
17 Replies 17
balaji.bandi
TM_DATA_PARITY_ERROR - this is more of a BUG
Not necessarily required any change, the bug has developed the symptoms. the suggestion here is either old or new SUP card upgrade and load the config if you have a backup copy of the config to restore back services.
Since it is ROMMON mode you have the option to upgrade now.
try tp upgrade and let us know.
Note: SUP 720 is too old and end of the sale and support long back. if you looking  to upgrade looks at new supervision cards SUP2T at least for now to resolve the issue
Steps  to recovery from ROMMON :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/17050-14.html
BB
What does "try tp upgrade" mean? Does that mean try upgrading to a known fixed code version on my current SUP?
I was also curious about the fiber modules I have installed in slots 1 and 2. If I get a new SUP and insert it without my saved configuration, do I need to remove the SFPs out of modules 1 and 2 since the new SUP won't have my running config on it out of the box?
Thank you for such a quick reply by the way!
There are a couple of options here : lets start with what you have
1. with the existing SUP 720 in ROMMON Mode, do dir if you find the image in flash
2. boot flash:/image.bin (change the image name here based on the file available in the flash)
Once it boots success, please post complete output of boot process and show version output (once you get # prompt)
Then we can discuss an upgrade or move to new modules.
BB
Ok. At the moment the SUP is up and running and working right now. Our 3rd party TAC support was able to help with this last night with getting boot image to work in ROMMON.
I can get the information you are requesting tomorrow if you don't mind.
balaji.bandi
Sure when you get a chance please to provide so we can suggest an upgrade to the new IOS or if you like you can change the supervisor if required.
what is the TAC suggestion? upgrade or replace?
BB
TAC support said if this only occurs once this could just be something with environmentals and can be ignored;  based on this document: https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/116135-trouble-6500-parity-00.html
This 6506 has been in place for years in this same closet and I just have a weird feeling that it's just some environmental but maybe it could be. I've recently upgraded the UPS that this runs off but it's been running fine for several months.
Show us the exact error message.
Post the complete output to the following commands:
sh version
sh module
NOTE
I want to see everything except the hostname and the IP address.  Do not edit anything out.
thanks for the information, can you provide show version
BB
See below
For Cisco community:
SHOW VER
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXJ2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Dec-11 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
SWITCH NAME uptime is 1 day, 10 hours, 33 minutes
Uptime for this control processor is 1 day, 10 hours, 33 minutes
Time since SWITCH NAME switched to active is 1 day, 10 hours, 32 minutes
System returned to ROM by s/w reset at 18:59:00 CDT Sat Jan 9 2021 (SP by error - a Software forced crash, PC 0x41A01650)
System restarted at 21:06:07 CDT Sat Jan 9 2021
System image file is "disk1:s72033-ipservices_wan-mz.122-33.SXJ2.bin"
Last reload reason: error - a Software forced crash, PC 0x425E76DC
cisco WS-C6506-E (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID SAL092438YF
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
1 Virtual Ethernet interface
98 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
SHOW MODULE
show module
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAD102605V7
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAD102302NL
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD0929085Y
6 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-45AF SAL09316MCC
Mod MAC addresses Hw Fw Sw Status
1 0018.19ee.1420 to 0018.19ee.1437 2.3 12.2(14r)S5 12.2(33)SXJ2 Ok
2 0018.1868.7ff8 to 0018.1868.800f 2.3 12.2(14r)S5 12.2(33)SXJ2 Ok
5 0011.9202.2934 to 0011.9202.2937 4.4 8.1(3) 12.2(33)SXJ2 Ok
6 0014.f2cf.f2d8 to 0014.f2cf.f307 1.1 7.2(1) 12.2(33)SXJ2 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1025SGEW 2.0 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL1026TF24 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAD0927056R 2.1 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD092607JG 2.3 Ok
6 IEEE Voice Daughter Card WS-F6K-GE48-AF SAL09316N0Q 1.2 Ok
Mod Online Diag Status
1 Pass
2 Pass
5 Pass
6 Pass
Post the entire lot into a text file and then attach the text file into your next response:
sh log system disk bootdisk:sea_log.dat
sh log system console disk bootdisk:sea_console.dat
These commands are not working for me.
I get this message:
SWITCH NAME#show log system disk bootflash:sea_log.dat
Cannot open file to read. File bootflash:sea_log.dat does not exist.
SWITCH NAME#show log system console disk bootdisk:sea_console.dat
% Invalid input detected at '^' marker.
Post the complete output to the following command:
dir
Out put of dir
Directory of disk0:/
1 -rw- 74259428 Aug 6 2005 13:08:08 -05:00 s72033-ipservicesk9_wan-mz.122-18.SXE2.bin
balaji.bandi
check if the files exits
dir bootflahsh:
dir bootdisk:
BB
