6509 error "Module Failed SCP dnld"
shiran.wang
My 6509-E
IOS version:15.1(2)SY7
process card:VS-S720-10G
issue description:after reboot line card can't load.
have an error message
Last transition recorded: (insert)-> may_be_occupied (timer)-> occupied (known)-> can_power_on (no_power)-> powered_off (operator_power_on)-> can_power_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)->
check_power_on (power_on_ok)-> wait_til_online
*Aug 16 06:18:56: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Module  Failed SCP dnld)
Router#sh module all
Mod Ports Card Type                              Model              Serial No.
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1520DPBE
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1336Y4WV
  7   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1519D64R
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  c89c.1de2.d064 to c89c.1de2.d093   4.1   Unknown      Unknown      Other
  5  0021.a094.8288 to 0021.a094.828f   3.4   8.5(4)       15.1(2)SY7   Ok
  7  6400.f1e3.ab90 to 6400.f1e3.aba7   5.0   Unknown      Unknown      Other
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1518CRN2  4.1    Other
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1337YE4A  1.2    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1337YHGY  5.2    Ok
  7  Centralized Forwarding Card WS-F6700-CFC       SAL1518D0P3  4.1    Other
how can i fix this problem?
thanks!
Mark Malone
here is the troubleshoot doc for that exact issue follow every step in it see if it comes backonline , if not may need rma
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/116115-trouble-linecard-00.html
I don't know the figure means,
Router#remote command switch  show scp counters
received packets            = 26289
transmitted packets         = 15686
retransmitted packets       = 11
fast retransmitted packets  = 0
loop back packets           = 10625
transmitted expedited pkts  = 0
received packets            = 26673
transmitted packets         = 15710
loop back packets           = 10985
Router#remote command switch  show scp status
Rx 27075,  Tx 15734,  scp_my_addr 0x4
Id Sap      Channel name    current/peak/retry/dropped/total  time(queue/process/ack)
0  11   SCP Unsolicited:11      0/    0/    0/      0/    0      0/   0/   0
1  20   SCP Unsolicited:20      0/    0/    0/      0/    0      0/   0/   0
2  0    SCP Unsolicited:0       0/    2/    0/      0/ 6400      0/   0/7016
3  2    SCP Unsolicited:2       0/    3/    0/      0/ 6456      0/   0/   0
4  21   SCP Unsolicited:21      0/    0/    0/      0/    0      0/   0/   0
5  16   SCP Unsolicited:16      0/    0/    0/      0/    0      0/   0/   0
6  1    SCP Unsolicited:1       0/    3/    0/      0/   51      0/   0/ 324
7  18   SCP Unsolicited:18      0/    0/    0/      0/    0      0/   0/   0
8  17   SCP Unsolicited:17      0/    0/    0/      0/    0      0/   0/   0
9  33   SCP async: LCP#5        0/   32/    0/      0/ 2955    316/ 280/   4
00:24:35: SP:     scp_dnld_module 2 : 0 : 0: during state enabled, got event 3(dnld_failed)
00:24:35: SP: @@@ scp_dnld_module 2 : 0 : 0: enabled -> download_failed
00:24:35: SP: Stop timer
00:24:35: SP:  Slot 2 changed status to FAILED
Aug 16 16:30:12: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Module  Failed SCP dnld)
00:24:35: SP: scp_dnld_oir_status(2): status = 0
00:24:35: SP:     scp_dnld_module 2 : 0 : 0: during state download_failed, got event 2(disabled)
00:24:35: SP: @@@ scp_dnld_module 2 : 0 : 0: download_failed -> disabled
00:24:35: SP: disable_action(2/0):
00:24:35: SP: stop_download_process() slot/proc 2/0, download_pid: -1 my_pid: 77 image_fd: -1
00:24:35: SP: is_module_under_rapid_boot: slot: 2, status: 0
00:24:46: SP: scp_dnld_oir_status(2): status = 0
00:24:46: SP:     scp_dnld_module 2 : 0 : 0: during state disabled, got event 2(disabled)
00:24:46: SP: @@@ scp_dnld_module 2 : 0 : 0: disabled -> wait_til_enabled
00:24:46: SP: scp_dnld_oir_status(2): status = 1
00:24:46: SP:     sm_debug_init : debug already initialized
00:24:46: SP:     scp_dnld_module 2 : 0 : 0: during state wait_til_enabled, got event 1(enabled)
00:24:46: SP: @@@ scp_dnld_module 2 : 0 : 0: wait_til_enabled -> enabled
00:24:46: SP: Start REGN timer for 2 with 240 sec
Cisco TAC engineer tell me the line card must to be RMA,
this is an hardware problem
