05-10-2017 05:29 AM - edited 03-08-2019 10:31 AM
We have a VSS config of two 6509 (Sup720) which haven't been upgraded in ages and figured it was time to fix this.
Is it possible to do a ISSU upgrade from version 12.2.33-SXI to 15.1.2-SY10 ?
Or do we have to have downtime when going from 12.x to 15.x ?
Or would you recommend going to the newest 12.x first and then to 15.x ?
Solved! Go to Solution.
05-10-2017 07:08 AM
Unfortunately, ISSU/eFSU is not possible here; so yes, you will have downtime.
c6500 eFSU compatibility matrix: http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/catalyst6500/ios/SX_SY_EFSU_Compatibility_Matrix.xlsx
Rolf
05-10-2017 07:08 AM
Rolf
05-10-2017 07:12 AM
Thanks for the info, that spreadsheet will definitively come in handy.
