6513 %MLSCEF-SP-2-FIB_SSRAM_WRITE_INCONSISTENCY
Bradford.berry
I am getting the following error:
%MLSCEF-SP-2-FIB_SSRAM_WRITE_INCONSISTENCY:FIB SSRAM Mismatch for Index: 98305 Expected: 4000    , Hardware: B004000
My IOS
IOS (tm) s222_rp Software (s222_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF17b, RELEASE SOFTWARE (fc1)
My Sup's
  1    2  Catalyst 6000 supervisor 2 (Warm)      WS-X6K-S2U-MSFC2
  2    2  Catalyst 6000 supervisor 2 (Active)      WS-X6K-SUP2-2GE
sh mls cef hardware mod 2
  CEF TCAM v2:
  Size:
        65536 rows/device, 2 device(s), 131072 total rows
        32 entries/mask-block
        8192 total blocks (32b wide)
        0 - 4095 upper blocks, 4096 - 8191 lower blocks
        1179648 s/w table memory
  Used blocks:
        Upper bank:
          24 IP ucast
          0 IPX
          0 IP mcast
        Lower bank:
          0 IP ucast
          0 IPX
          0 IP mcast
        Max:
          26 IP ucast
          0 IPX
          1 IP mcast
  Free blocks (non-contiguous range):
        18 - 4095 upper blocks, 4096 - 8191 lower blocks
  Options:
        sanity check: on
            sanity interval: 301 seconds
        redistribution: off
            redistribution interval: 120 seconds
            redistribution threshold: 10
        compression: on
            compression interval: 31 seconds
        serialization: on
            serialization interval: 16 seconds
        recovery: on
            recovery interval: 3 seconds
        bank balancing: off
            bank differential limit: 5
        rpf mode: off
        tcam shadowing: on
        Fatal Error Handling Status: RESET
  Background Task statistics:
        sanity check count:             0000000000046632
        Consistency check count:        0000000000450547
        Consistency check errors- TCAM: 0000000000000000
        Consistency check errors- SSRAM:0000000291167124
        block redistribute count:       0000000000000000
        IP ucast serialize count:       0000000000000001
        IP mcast serialize count:       0000000000000000
        IP ucast recover count:         0000000000000000
        IP mcast recover count:         0000000000000000
        block compress count:           0000000000002181
               IP ucast [32]:       0000000000000110
  Hardware switching status:
        ip switching:  on
        ipx switching: off
Any help would be great.
Brad
0 Replies 0
