vlan problem catalyst
Hello I have a message error can anyone help me?
What is that: Local updater ID is 10.X.X.254 on interface Vl1 (lowest numbered VLAN interface found)
(config)#vlan 200
(config-vlan)#name PRUEBA
(config-vlan)#exit
% Applying VLAN changes may take few minutes.  Please wait...
VLAN 1003 parent VLAN missing
APPLY VLAN changes failed
sh vtp status
VTP Version                     : 3 (capable)
Configuration Revision          : 172
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 54
VTP Operating Mode              : Server
VTP Domain Name                 : XYZ
VTP Pruning Mode                : Enabled (Operationally Enabled)
VTP V2 Mode                     : Enabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xCB 0xFF 0x6F 0x28 0xA6 0x8D 0x25 0x9E
Configuration last modified by 10.40.100.238 at 11-22-11 16:18:53
VTP version running             : 2
sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 01:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX6, RELEASE SOFTWARE (fc1)
System image file is "sup-bootdisk:s72033-ipservices_wan-mz.122-33.SXI5.bin"
Last reload reason: VSLP HA role change from active to standby
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
45 Virtual Ethernet interfaces
54 Gigabit Ethernet interfaces
20 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
Bart Kersten
Vlan 1003 is a default tokenring vlan. And therefore can not be used.
Hope this helped
Thank Bart for this information but I tried to create vlan 200 do not 1003. any idea?
Best Regards.
Santiago
Bart Kersten
Oke sorry i misunderstood. You might want to reffer to this, it is similar to your problem.
https://supportforums.cisco.com/thread/2027277
Good luck!
