NAT Problem
remco.gussen
Level 4
Level 4
I'm trying to set up a nat implementation in my network.
I defined the ip nat inside / outside commands on the right interfaces. A overload mechanism works ok and i want a static nat entry too. The ip nat inside source static 172.17.9.2 10.239.250.66 is entered. The access list for the overload mechanism works fine. However, the static nat doesn't work. A ping or whatever isn's posible. When i enter debug ip nat, i can see that he's translating the address.
Why isn't there any commnunication posible through this static nat ?
Gr.
Remco
12 Replies 12
jlkeys
Level 2
Level 2
Which address is inside and which is outside?
the static NAT should take preference over the dynamic pool. Perhaps there is a dynamic entry already which needs clearing?
I already checked this document. According to me, there is nothing wrong. Maybe a bug in the IOS ?
plz specify a ping from where to where...also can you post your ACL? Thx!
[EDIT]
Also what protocol/port did you specify on the static nat entry i.e.
ip nat inside source static tcp "inside ip" 25 "outside ip" 25
[EDIT-2]
Do you have any route maps? If so, plz post, if not try implementing one.
amit-singh
Level 11
Level 11
Hi Remco,
Do you have any other ip address in the range 10.239.250.x. If your config is all correct and you have used the correct statements, then I would suggest you to try changing the NAT with a different IP. I have been into the same situation where the IP given to me by ISP was already in used and it didnt work for me. I requested another IP and it worked for me.
Just trying to relate it in case if you config is all correct. You can paste your config and let us check.
HTH, Please rate if it does.
-amit singh
This is (a part of) my config:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.309
description ***-Data
encapsulation dot1Q 309
ip address 172.17.9.250 255.255.255.0
ip nat inside
interface FastEthernet0/0.409
description ***-Management
encapsulation dot1Q 409
ip address 10.239.9.240 255.255.255.0
interface FastEthernet0/0.500
description Shared-Internet
encapsulation dot1Q 500
ip address 10.239.250.65 255.255.254.0
ip nat outside
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Serial0/1
no ip address
shutdown
interface BRI1/0
no ip address
shutdown
interface BRI1/1
no ip address
shutdown
interface BRI1/2
no ip address
shutdown
interface BRI1/3
no ip address
shutdown
ip nat inside source list 10 interface FastEthernet0/0.500 overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.239.251.254
ip route 172.16.4.0 255.255.255.0 10.239.9.254
no ip http server
access-list 10 permit 172.17.9.0 0.0.0.255
access-list 23 permit 172.16.4.0 0.0.0.255
line con 0
exec-timeout 0 0
login local
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 0 0
login local
end
Hi Remco,
1. To clear nat translations you can use
router# clear ip nat translations *
This will remove all the dynamic entries from the nat table
2.
For your nat static rule,
(a)
I see that outside interface has ip address '10.239.250.65' and you are specifying "10.239.250.66" which is in this network. Not sure if it is allowed.
If it is allowed
(b)
Can you try giving the below and check if you can see "172.17.9.2" under inside local and "10.239.250.66" under inside global
router# sh ip nat translations
If there is an entry under it then NAT translation might be working fine. The problem could be with ping.
As per the config you sent, I am guessing when you use ping command from your inside network, the echo request packet would have been sent to 10.239.251.254
So check on 10.239.251.254 if there is a route to 10.239.250.66?
If it not there then you give the following command
10.239.251.254(config)# ip route 10.239.250.66 255.255.255.255 10.239.250.65
HTH,
Radhika
Hi Radhika
I already tried to clear the nat translations. No effect....
I already tried the "show ip nat translation" command and indeed, it shows the correct inside local and inside global addresses.....
The route isn't needed. Is is in the same network as the outside interface (10.239.250.65 /23 is in the same network as 10.239.251.254). And with the overload mechanism everythings works fine.....
I realy don't know where to find the problem... Maybe a problem with the IOS version ??
Gr.
Remco
Hi Remco
You could try two things (listed in my order of pref):
1) in your access list for the outbound overload nat, deny the address that has a static nat
2) Use a route-map for matching the overload NAT as this works on a host/port basis rather than just host.
Good luck
Dan 🙂
Hi All,
I think configuration of nat is OK but
" ip nat inside source static 172.17.9.2 10.239.250.66 "
Lets think about the L2-L3 mapping. router is translating the inside address 172.17.9.2 to outside address 10.239.250.66 but when the Machine on the network 10.239.250.0/23 try to access 10.239.250.66 it should have a L3-L2 mapping mean ARP entry for sending packets right so you need to have this IP configure on atleast one device which can reply to arp request with the mac address which is not happening in your case.
What i will suggest you to configure this ip adddress on the router's outside interface as secondary so that router will reply ARP packet for that ip address.
You can try putting static entry in your next hope router for 10.239.250.66 and the mac address of the NAT router's outside interface. but that this solution will work for router only no other PC will be able to access 172.17.9.2
i hope you understood the problem.
Please rate the post if it helps
thanks
kamlesh
Problem Solved !
Behind this NAT router, there is another PIX 515 Firewall. The 10.239.250.65 address is translated there to a real public ip address. I tried to NAT the 10.239.250.65 address to another free public address and everything works... Strange... A problem with a single public ip address in a complete public range ?
Thanx for the support anyway..
Gr,
Remco
