881W configured as AP
habana1020131
Hi I'm configuring a CISCO881W as an AP only. User get connected to the WIFI but they can't go to Internet. I can ping google IP from the AP module but I can not ping user's IP under the AP.
Can any one help me with this issue?
Thanks in advance!
17 Replies 17
I did that also, and it doesn't work.
I had tried with no gateway, with gateway only in the router module, with AP pointing to router module and router module pointing to the gateway 36.36...
I don't know what else to do.
Hello
So you disabled ip routing on the GERO_MAC router and it still was failing?
Can you post a diagran of how this is setup
My understanding is something like this:
Subnet 192.16.36.x/24
                                        .x Dhcp Client <--AP> .253
                  GERO_MAC-RTR .254   |   Router .36 <---------> Wan
res
Paul
Kind Regards
Paul
Yes, is exactly like that.
But the problem now, is that I did an upgrade and all that I get is a prompt ap:
I don't have firmware into the flash, it doesn't let me copy anything into the flash... so I don't know if there's other way to get him to live again...
