Showing results forĀ
Search instead forĀ
Did you mean:Ā
9200 and 6500 WS-X6724-SFP compatible?
baselzind
Level 6
Level 6
is  a C9200L-24P-4G-E switch compatible with my 6500 with a WS-X6724-SFP module if connected on both side using this sfp GLC-SX-MM? especially the 9200 being very new and my 6500 module is very old
MMD sfp should work that module - as per my notes last i was tested with WS-X6748-SFP and Cat 9300 works as expected.
BB
balaji.bandi
i have seen some issue on cat 9K GLC-SX-MM ( after moving to GLC-SX-MMD all worked as expected.)
https://tmgmatrix.cisco.com/?si=GLC-SX-MM
BB
I see especially with GLC-SX-MM EOL , but would a 9200 work with my WS-X6724-SFP module? I'm worried to buy multiple switches that ends up not compatible with my core
BB
