9200 fixed and modular switches in the same stack not supported
Madura Malwatte
Level 4
Level 4
It seems a 9200 modular and 9200L fixed switch cannot be stacked together in the same stack due to the modular model using Stackwise-160 and fixed model using Stackwise-80. Can someone confirm this is the case, that stacking will never work with these two models together in the same stack?
Or can the 9200 be dropped down to Stackwise-80 so it matches with the 9200L, hence can be part of the same stack?
Going by the whitepaper - https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html#_Toc13521183
"however, it is not possible to mix the9200 and 9200L models due to different stacking bandwidth."
Reza Sharifi
That is correct. The 2 cannot be mixed. 9200 with 9200 and 9200L with 9200L.
Reza Sharifi
balaji.bandi
yes you can not mix those, that is the limitation of the models.
BB
Madura Malwatte
Level 4
Level 4
thanks for the confirmation
