9200 switch loosing its configuration
Asfandyar70754
Hi guys,
One of my friend is facing a issue and it seems quite weird.
2 of his 9200 switches lost their configuration even though configuration was saved and even if for some reason switch restarted but they should not  loose its configuration.
what could be the issue here?
7 Replies 7
Leo Laohoo
Post the complete output to the following commands:
sh version
dir nvram:
When this happens, do the switch(es) boot into ROMMON?
marce1000
  - Check the config register setting(s) on the involved devices.
 M.
balaji.bandi
check this should be - show verion give you below information.
Configuration register is 0x102
BB
If I can jump on this one. We have a 9200 that the config register seems to be stuck at 0x142.
we have set it to be 0x102, and it says it will be on next reboot, but every time it reboots it is still:
Configuration register is 0x142 (will be 0x102 at next reload)
it just will not change to 102. Have any of you ever seen this?
thanks
          - Please start a new thread, much better to get  your problem in the spotlight.
 M.
Raise a new thread because this behaviour is totally different to this thread.
In the new thread, post the complete ROMMON output to the following command:
set
hello i have the same issues how did you solve your problem please?
