9200 vlan interface not pingable/not connected
rsblind
I have a 9200 with 5 vlans setup. vlan 10, 12, 13, 15 and 100. All have interfaces. I can ping all of them but vlan 10. I'm not seeing the issue.  I running the ping from the switch...  Why is it not showing as a connected vlan on show ip route?
interface Vlan10
description Data
ip address 172.25.10.1 255.255.255.0
interface Vlan12
description CorpWireless
ip address 172.25.12.1 255.255.255.0
interface Vlan13
description Servers-Printers
ip address 172.25.13.1 255.255.255.0
interface Vlan15
description Mgmt
ip address 172.25.15.1 255.255.255.128
interface Vlan100
ip address 192.168.120.1 255.255.255.0
ip access-group guest-wireless-in in
ip access-group guest-wireless-out out
Show IP Route
Gateway of last resort is 172.25.15.10 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.25.15.10
S 10.0.0.0/8 [1/0] via 172.25.15.10
S 172.16.0.0/12 [1/0] via 172.25.15.10
172.25.0.0/16 is variably subnetted, 6 subnets, 3 masks
C 172.25.12.0/24 is directly connected, Vlan12
L 172.25.12.1/32 is directly connected, Vlan12
C 172.25.13.0/24 is directly connected, Vlan13
L 172.25.13.1/32 is directly connected, Vlan13
C 172.25.15.0/25 is directly connected, Vlan15
L 172.25.15.1/32 is directly connected, Vlan15
S 192.168.0.0/16 [1/0] via 172.25.15.10
192.168.120.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.120.0/24 is directly connected, Vlan100
L 192.168.120.1/32 is directly connected, Vlan100
Thanks in advance...
RS
2 Accepted Solutions
since the SVI subnet not appear in show ip route
then this SVI is down/down
you need to assign access port to this VLAN to be UP or use
no autostate command
you can add vlan 10 to some port with status up. also you can add that to some trunk link with status up.
Good luck
KB
6 Replies 6
share #sh ip int bri
output
Good luck
KB
Ok, interesting... Why would it be status: up, Protocol: down...
#sh ip int bri
Vlan1 unassigned YES NVRAM administratively down down
Vlan10 172.25.10.1 YES NVRAM up down
Vlan12 172.25.12.1 YES NVRAM up up
Vlan13 172.25.13.1 YES NVRAM up up
Vlan15 172.25.15.1 YES NVRAM up up
Vlan100 192.168.120.1 YES NVRAM up up
GigabitEthernet0/0 unassigned YES NVRAM administratively down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset up up
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/4 unassigned YES unset down down
GigabitEthernet1/0/5 unassigned YES unset up up
Ok, so if no one is connected then the interface will not ping? 90% of the ports on this switch are access and assigned to vlan 10... But, no one is currently on, so all the vlan 10 ports are "notconnect"... The other vlans 12, 13, 15 & 100 all have something connected.
Good luck
KB
Thanks guys...
