9300 / 9500 IOS Update from USB Drive
mattipler
Hey guys,
I'm looking to upgrade the IOS on a number of 9300 / 9500 switch stacks from a USB data pen (something I've not done before).
These stacks are deployed however not yet in production and I unfortunately do not have remote access to them. I've done some scouring of the 9300 / 9500 documentation and have been unable to find a clear answer to my query.
Hoping one of you guys has previous experience with regards to my scenario / requirement. If I...
  • FAT32 format my USB pen.
  • Copy my target / updated .bin IOS image to it.
  • Console onto the 9300 / 9500 in question.
  • Insert my USB pen into the master of the 9300 / 9500 stacks (at this point I should receive a prompt indicating usbflash0 is connected?)
  • Run show ver to clarify my current version.
  • Copy .bin file from USB drive to flash copy usbflash0:cat9k_iosxe.16.09.04.SPA.bin flash:
  • Within conf t set the new IOS as the new image boot system flash:cat9k_iosxe.16.09.04.SPA.bin
  • Once tested delete /recursive /force flash:cat9k_iosxe.OLD.SPA.bin
Will this following a reload have the desired effect? Will this update all stack members? Is there anything I'm missing? Is the above inaccurate?
Really appreciated the assistance. I don't have a test environment in which to play this out.
Cheers.
Matt
balaji.bandi
2 Things :
Cat 9300 Upgrade is different compare to Cat 9500
Cat9300 is Stacking technology
Cat 9500 StackWise virtual
Cat 9300 here is the steps :
 copying the image file into the root of a drive and insert the USB in the USB slot at the front of the 9300.
 copying a new image onto the switch/flash remove all unnecessary files using the following command:  Switch# request platform software package clean switch all
Confirm that the switch is able to recognise the file system.
dir usbflash0:
Switch# copy usbflash0:cat9k_iosxe.16.06.03.SPA.bin flash:
Install the software.
Switch# request platform software package install switch all file flash:cat9k_iosxe.16.06.03.SPA.bin auto-copy
Restart the switch
Switch# reload
Verification once it reloaded :
Switch# Show version | include install
Cat 9500 here is the steps :
http://www.balajibandi.com/2019/10/11/cat-9500-stack-wise-virtual-configuration/
BB
24 Replies 24
balaji.bandi
2 Things :
dir usbflash0:
Restart the switch
Switch# reload
BB
Thank you very much sir! Much appreciated guidance. :)
So 9300...
1. Post upgrade clean-up.
2. Verify USB accessibility / readability.
Switch#dir usbflash0:
3. Copy image to flash.
4. Perform install across all switches.
Switch#request platform software package install switch all file flash:cat9k_iosxe.16.06.03.SPA.bin auto-copy
5. Restart.
Switch# reload
6. Verification of image version.
9500
1. Verify USB accessibility / readability.
2. Copy image to flash.
3. Software installation across 9500 switches.
Switch#install add file flash:cat9k_iosxe.16.06.02.SPA.bin activate commit
4. Soft installation verification.
Switch#show install summary
5. Removal of inactive image.
Switch#install remove inactive
Does that seem roughly "the ticket"? :)
Thanks again - really appreciate the assistance.
Matt
16.6.3?
Upgrade to 16.6.3? Geez!
Did someone read the Release Notes, particularly the OPEN Caveats for 16.6.3?
@Leo LaohooLaohoo that is not my intention -this is only procedure how to process works, not that recommended to upgrade - hopefully, you understand what I said in the post.
BB
Me bad. I thought that was the OPs intended version.
I have a problem when I am upgrading 9300 IOS by usb drive with IOS file but switch can't find my usb drive by dir flash: command. Can somebody give me an idea?
James
dir usb0:
Leo,
My 9300 switch is running and I insert UPS with IOS into the switch UPB port. On the switch platform I type: dirusb: command, but switch is showing
"% Invalid input detected at '^' marker". Do you know steps how to format the USB on the switch platform? Thanks
Leo,
“% Invalid input detected at '^' marker”. Do you know steps how to format the USB on the switch platform? Thanks
My USB is exFAT format.
format in the switch itself
USB needs to be in FAT32 Format
@JamesZeng7831
i suggest to open a new thread for the issue you having.
Quick help here is :
you need to Format the USB : Format the USB  flash storage FAT32  to recognise the USB
When you Plug the USB, you can see the Log message if success.
BB
Yes, after I formatted my USB to FAT32, I successed upgrade my 9300 IOS.
James
