03-26-2021 03:14 AM
I have configured 9300 switch with management on MGMT port. No IP defined on vlan or physical interfaces.
I have configured snmp V3 and I am unable to monitor the switch using my NMS software. Is there any specific setting need to be defined to monitor on MGMT interface?
03-26-2021 03:20 AM
Hi there,
Have you appended all of your snmp-server statements with use-vrf Mgmt-vrf ?
cheers,
Seb.
03-26-2021 03:57 AM
please provide the commands.
I have defined the following
SNMP-Server group TestSNMPv3Group v3 priv Read TestSNMPv3View Write TestSNMPv3View
SNMP-Server group TestSNMPv3Group v3 priv context vlan match prefix
SNMP-Server view TestSNMPv3View Internet included
SNMP-Server user TestSNMPv3User TestSNMPv3Group v3 auth SHA 1q2w3e4r priv AES 1q2w3e4r
03-26-2021 03:22 AM
- You may also have some manual snmp v3-based command line testing , before using the NMS.
M.
03-26-2021 11:16 AM
I found similar problem on the following link, is it still not resolved on 9300?
https://community.cisco.com/t5/mpls/snmp-access-to-interface-in-vrf-mode/td-p/486197
