Bookmark
Subscribe
2068
9300 Stack Redundancy not rebuild after Reboot
we have a Stack 2x C9300L-24P-4X
did Switch reboot, but noticed that switch does not change to Role to "Standby" , but to Role "Member" instead
- in "Redundant System Information" is Hardware Mode = Simplex (instead of Duplex)
How can we ensure that switch will join back and not fly out after reboot ?
#sh redundancy
Redundant System Information :
Available system uptime = 6 days, 17 hours, 12 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Configured Redundancy Mode = sso
Operating Redundancy Mode = Non-redundant
Maintenance Mode = Disabled
Communications = Down Reason: Failure
Current Processor Information :
Active Location = slot 1
Current Software state = ACTIVE
Uptime in current state = 6 days, 17 hours, 12 minutes
Image Version = Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 03-Jul-21 01:55 by mcpre
BOOT = flash:packages.conf;
CONFIG_FILE =
Configuration register = 0x102
Peer (slot: 0) information is not available because it is in 'DISABLED' state
Best Regards
Boris
2 Accepted Solutions
I do not see any issue here as per the output.
Turn off whole stack and bring back and test it. (if you going this route, make switch priority also, and save the config - before you reload)
BB
we did the following:
remove Stacking Cables
delete Stack 1+1-Mode with command "unset STACK_1_1" (in ROMmon Mode/console).
after cold boot the switch was again in Stack and it took 5min to take the Standby Role .
thanks for help !
5 Replies 5
balaji.bandi
post  below output :
#show switch detail
#show switch stack-ring speed
If you like provisionbing you can do below config also setup a priority so master can be elected.
switch 1 provision c9300-XX
switch 2 provision c9300-XX
BB
here the output:
#sh sw detail
Switch/Stack Mac Address : *8.4e80 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active *.4e80 1 V01 Ready
2 Member *.5e80 1 V01 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 OK OK 2 2
2 OK OK 1 1
#sh switch stack-ring speed
Stack Ring Speed : 320G
Stack Ring Configuration: Full
Stack Ring Protocol : StackWise
Provisioning was already configured, here output from Running config:
switch 1 provision c9300l-24p-4x
switch 2 provision c9300l-24p-4x
BR
l think the output looks fine, do you find anything suspicious ?
Best Regards
Boris
BB
thanks for help !
