12-09-2024 12:13 AM
Dear community memebers,
I need to test a scenario containing cisco nexus 9300 switches on a virtual lab. I tried to configure vpc on my switches both in eve and gns3. But I have a problem. I configured my switches, and the vpc is formed fine and is up. It has some port members which they are up too. but the vpc port channel is not working properly. I checked some command outputs which are given bellow.
Can you help me solve the issue to be able to test my scenario, please?
(configurations and the topology are provided too)
I checked this command. You can see the output:
show port-channel load-balance forwarding-path interface port-channel 11 src-ip 1.1.1.1 dst-ip 2.2.2.2
Unknown error.
Error: 0x41a10000
PD Error: -3
(Please check if PO has members and is UP)
But PO has member and is up. look:
sw1(config)# sho vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 2
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Delay-restore Orphan-port status : Timer is off.(timeout = 0s)
Operational Layer3 Peer-router : Disabled
Virtual-peerlink mode : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po10 up 1
vPC status
Id Port Status Consistency Reason Active vlans
3 Po3 up success success 1
11 Po11 up success success 1
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
sw1(config)# sho port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
3 Po3(SU) Eth NONE Eth1/3(P)
10 Po10(SU) Eth LACP Eth1/4(P) Eth1/5(P)
11 Po11(SU) Eth LACP Eth1/1(P) Eth1/2(P)
sw1(config)# sho interface brief
Port VRF Status IP Address Speed MTU
mgmt0 -- up 172.11.11.1 1000 1500
Ethernet VLAN Type Mode Status Reason Speed Por
t
Interface Ch
Eth1/1 1 eth trunk up none 1000(D) 11
Eth1/2 1 eth trunk up none 1000(D) 11
Eth1/3 1 eth trunk up none 1000(D) 3
Eth1/4 1 eth trunk up none 1000(D) 10
Eth1/5 1 eth trunk up none 1000(D) 10
12-09-2024 12:20 AM
Try different latest images of Nexus image.
I work on a day-to-day nexus environment where the command works as expected. Check the correct syntax :
12-09-2024 06:04 AM
I tried several images and the problem is not solved. the eve and gns3 are both the latest version and I tried nxos 10.3.1F and 10.2.3F which are both new.
As you can see the vpc port-channels are all up without problem, so the config shouldn't be wrong. But it does not work properly. (it works on real switches but it does not on eve or gns)
If you already have a lab on eve or gns with vpc configured, can you check this command and inform me if it works fine:
12-09-2024 12:47 AM - edited 12-09-2024 06:04 AM
