Showing results forĀ
Search instead forĀ
Did you mean:Ā
AAA authentication sequence
bapatsubodh
If we have configured the following aaa authentication command
aaa authentication login default group radius local
username localuser priv 15 password *****
enable secrte ********
Case 1.
In this case if the router can reach the radius server  and if we try to access the router with local username localuser and it's password will it get authenticated? Or it will contact the RADIUS server and then it will reject the username and password.
If this CASE 1 is true then is there any way to have a username locally in router that is not on the availabe in RADIUS and then use it to login to the router.
Case 2;
Radius server is down and if try to access the router with local user name and password. I gues router should use the local username database for authentication.
Please share the experience.
Thanks in advance
Subodh
cadet alain
Case 1:
the local username/password will only be used if radius server is unavailable. You can use a named method instead of default specifying local database and apply it to a specific line with the login authentication >method name> command:
-aaa authentication login NAMED local
- line vty 1
  login authentication NAMED
Case2: correct
Regards.
Alain.
Case 1:
The local database won't be used as long as it can get a response from the radius server.
Case 2:
It will use the local database if it can't contact a radius server.
John
HTH, John *** Please rate all useful posts ***
