About Cisco Switch Stack
Smile丶
Level 2
Level 2
I have some question about Cisco Stack.
1.Do I need the same model, license and IOS software versions to stack between 9300 sku?
2.How many C9606R can I stack?
3.Can I do virtual stacking on channelports.For example,if I make 8 ports of the same type on two C9606R line cards into channelport, can I create stacked links on these two channelports?
5 Replies 5
Leo Laohoo
  1. 9300L can only be stacked with another 9300L.
  2. 9300L cannot be stacked with a plain 9300 nor 9300X.
  3. Same firmware version.
  4. Install mode or Bundle mode and not both.
Leo Laohoo
Two
Thanks for your reply, as I write the third question,can I create a stacked link on  two channelports(have 8 ports).
Leo Laohoo
IF there is a VSS pair, a Port Channel with 5 physical ports from switch 1 and 3 ports from switch 2 can be configured.
Thkans for your reply!Sorry,I still have a doubt that why both switches dont make a Port-Channel with 8 physical ports?
Five on one side and three on the other. Isn't the speed at both ends different?
Thanks again!
