acceptable signal loss and power levels for 10Gig Connections
dan hale
Level 3
Level 3
Hi All, trying not to be too vague, but what is the acceptable loss of signal and TX/RX power needed for a 10gig connections?
I'll be setting up a 5mile connection via my companies dark fiber which will pass thru several buildings and LIU's.
I've requested our communications team run a fiber tester on the new link prior to putting any optics on the length.
What would be the range I'm looking for signal and TX/RX power I should be?
The optics I will be using is SFP-10G-ER
Dan
Reza Sharifi
As long the fiber test shows DB losses are within the secs for single mode fiber, you should be fine.
here is good doc for reference:
http://www.thefoa.org/tech/FAQS/FAQ-TEST.HTM
A post in this discussion has been removed due to possible misconduct. Please refer to the CSC terms of use for more details.
