Access and Trunk configurations on the same port.
Mike Bowers
I was hoping someone could help point me in the right direction here. I thought i had a good grasp of access and trunk mode (a port can be one or the other, right?), but I've run into a client setup that seems to use both.  Below are two examples, fa0/22 is in access mode but has a trunk command and fa0/24 is in trunk mode but has an access command. If the port is in access mode and set to tag all traffic coming in as vlan 3, what in the world does the switchport trunk native vlan 2 command do?
In what ways can this configuration be used for?  Thanks!
interface FastEthernet0/22
description connected to Pix Firewall
switchport access vlan 3
switchport mode access
spanning-tree portfast
2960-1#show interfaces fastEthernet 0/22 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 3 (internet)
Trunking Native Mode VLAN: 2 (companylan)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
interface FastEthernet0/24
description connected to Cisco AP
switchport access vlan 2
switchport mode trunk
2 Accepted Solutions
cadet alain
Switchport: Enabled
This port is an access port and the  switchport trunk native vlan 2 command will have no effect until it is a trunk port.
Regards.
Alain
Hi Jimmy,
In addition to Alain's perfect replies, recall that the switchports on Cisco Catalyst switches can operate in dynamic modes, i.e. they will negotiate their operating mode with the connected device. This means that a single port can act as an access port to a normal PC but when a Cisco switch is connected to it, the port can become a trunk automatically. This in turn means that you should be able to have both access mode and trunk mode configurations present on this port so that the appropriate configuration can be chosen whenever the port comes up and negotiates a particular operating mode. Hence the possibility of having both access and trunk mode config on a single switchport. The rationale is really simple here but many people are still confused quite often.
Best regards,
Peter
7 Replies 7
cadet alain
Switchport: Enabled
Regards.
Alain
Thanks alain for the quick response. I was 90% sure but I wanted to verify. So it looks like when changing that port it in the past from a trunk port to an access port, all of the commands weren't cleaned out.
In the same way, the following switchport access vlan 2 has zero effect and can be removed without affecting anything?
Thanks again!
yes it can be removed if the port is a trunk port,it will only take effect when the port is an access port( operational mode).
In previous example the administrative mode was access( switchport mode access) so it could nevr be in operational mode trunk
but here the administrative mode is trunk(switchport mode trunk) so it could be in operational mode access and then the command
would take effect.But in your  case it was in operational mode trunk so it has no effect as of now.
Regards.
Alain
Ive seen these configs on devices and always wondered about them, thanks for the explanation.
Hi Jimmy,
Best regards,
Peter
Aye, aye, ty.  Great explanation.
Hi Peter,
Thanks for adding to the discussion and expanding on the answer. I appreciate it!
