ACL for Telnet Access
m.sienkiewicz
I was hoping to create an access list so that only a single IP address can telnet into the switch and all others would be blocked. I currently have a Catalyst 3550. Not having much luck. Any help would be appreciated.
5 Replies 5
Michael,
I would want you to "know what you are doing". Here is a link that might help you.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml#configurationex
Im sure if you google, you might get tons of configuration example, but as a network administrator, you should know exactly the desired result. The chances are that things can go wrong if you didnt.
Good luck, hope that url helps.
glen.grant
"access-list 1 permit xxx.xxx.xxx.xxx
lin vty 0 15
access-class 1 in
even better:
access-list 1 deny any log
michael.leblanc
Level 4
Level 4
access-list 101 remark --- VTY access, host & protocol restricted.
access-list 101 permit tcp host aaa.bbb.ccc.ddd any eq telnet
access-list 101 deny ip any any log
line vty 0 15
access-class 101 in
transport input telnet
Would be preferable to use SSH (TCP 22) rather than Telnet (TCP 23) though.
nbitbyte
ip access-list extended 101
permit tcp host a.b.c.d any eq 23
deny ip any any log
line vty 0 15
access-class 101 in
