ACL question
glodynto1
Frequent Visitor
Frequent Visitor
Hi all,
I'm fooling around with ACLs in my lab and had a question. I'm trying to use a standard access-list to permit only a number of hosts to another group of hosts over specific ports. I've created object groups and reference them in the ACL. When I add a permit any at the end of the ACL and try to apply the ACL to the interface where the Web-IPs reside, hosts outside of the group ADMIN-SERVERS I created are still able to talk to the hosts in the Web-IPs group. When I remove the permit any, I am unable to get to other hosts outside of Web-IPs group that are on the same network. this is my config so far
ip access-list SERVER-ADMIN
10 permit tcp addrgroup ADMIN-SERVERS addrgroup Web-IPs eq 443 log
20 permit tcp addrgroup ADMIN-SERVERS addrgroup Web-IPs eq 22 log
30 deny tcp any addrgroup Web-IPs eq 443
40 deny tcp any addrgroup Web-IPs eq 22
object-group ip address ADMIN-SERVERS
10 host 10.19.152.6
20 host 10.19.152.7
object-group ip address Web-IPs
10 host 10.19.2.100
20 host 10.19.2.101
30 host 10.19.2.102
interface Vlan2
ip access-group SERVER-ADMIN in
no shutdown
no ip redirects
ip address 10.19.2.2/24
Just wanted some input on whether I was misconfiguring the ACL or how it is being applied. Essentially just want the IPs in the SERVER-ADMIN group to be able to communicate on 443 and 22 to the IPs in the Web-IPs group - while also allowing other hosts in the same network (10.19.2.0/24) to be reachable normally. Let me know if I can be more clear on some of the details. Thanks
Joseph W. Doherty
Let me try to be more explicit.
would create an ACL like(?):
permit tcp host 10.19.152.6 host 10.19.2.100 eq 443 log
VLAN 2 is subnet 10.19.2.0/24
Applied as an IN, the source subnet is 10.19.2.0/24, but the ACL has 10.19.2.100/32 as the destination parameter!
Also, if ADMIN hosts are opening the contact with SERVERS hosts, the known port would be on the initial destination
permit tcp host 10.19.2.100 host 10.19.152.6 eq 443 log
So possibly, you need:
ip access-list SERVER-ADMIN-IN
 permit tcp addrgroup Web-IPs addrgroup ADMIN-SERVERS eq 443 log
 permit tcp addrgroup Web-IPs addrgroup ADMIN-SERVERS eq 22 log
ip access-list SERVER-ADMIN-OUT
!above denies redundant because of implicit ending ACE, deny any any
interface Vlan2
ip access-group SERVER-ADMIN-IN in
ip access-group SERVER-ADMIN-OUT out
11 Replies 11
M02@rt37
Hello @glodynto1
In your case, because all "Web-IPs" and other hosts in 10.19.2.0/24 are in the same VLAN, their trafic does not need to go through the SVI unless they are communicating with another subnet. That means your ACL won't affect host-to-host communication within the VLAN...
To enforce restrictions at Layer 2 (mean same vlan host 2 host control) use a VACL (Vlan Access Control List).
Best regards
The Web-IPs hosts are in the 10.19.0/24 vlan (let's say its vlan 2) while the admin servers are on the 10.19.152.0/24 vlan (let's say its vlan 152). I'm essentially trying to get a handful of hosts on vlan 2 only be reachable from a handful of hosts on vlan 152 using this ACL, so I don't believe it's host-to-host communication in the same vlan, unless I am misunderstanding something
krmp010608
Frequent Visitor
Frequent Visitor
From the flow it seems that the ACL is applied incorrectly, you can provide the output of the command:
show ip route 10.19.152.6
These hosts are directly connected to the same switch just on different vlans
so the sh ip route output doesn't yield
sh ip route 10.19.152.6
10.19.152.6/32, ubest/mbest: 1/0, attached
*via 10.19.152.6, Vlan152, [250/0], 3d00h
I thought simply adding an access-list to the SVI for vlan 2 saying only these hosts on vlan 152 are permitted to these specific hosts on vlan 2 would suffice
Can you send the switch configuration?
Joseph W. Doherty
Try
interface Vlan2
ip access-group SERVER-ADMIN out
Oops, my prior reply won't work because you're also using ports, so try, in your ACEs, reversing the dst and src address parameters, not ports, (while continuing to use in).
krmp010608
Frequent Visitor
Frequent Visitor
The configured ACLs are extended ACLs and it is recommended to apply them as close to the source as possible, you can do the following:
interface Vlan2
no ip access-group SERVER-ADMIN in
interface Vlan 152
I tried applying it to vlan 152 instead since that is closest to the source but seem to have the same behavior, I'm able to access the Web-IPs from hosts outside of the list of admin servers
From which specific IP can you access?
Joseph W. Doherty
interface Vlan2
