09-03-2008 04:16 AM - edited 03-06-2019 01:09 AM
Hello
If my trunk is in use between two switch, if I use the add command to add another vlan allowed in the trunk, Is there a cutoff network?
09-03-2008 04:24 AM
Hello Claude!
Use:
"switchport trunk allowed vlan add x"
and you will have no outage there.
Good luck!
Cheers,
Calin
09-03-2008 04:41 AM
Thanks a lot.
The addition "add" of a vlan in a trunk does not cut the networking of others vlan allowed in the trunk. Is Cisco has documented this because I found no documentation about that?
09-03-2008 05:02 AM
claude1968,
From what i interpreted, your question is "if I use the add command to add another vlan allowed in the trunk, Is there a cutoff network?
If you dont have the switchport trunk allowed vlan [vlan-id]command already enable on your trunk and you add that command, you will block all other vlans except the vlan you are allowing.
If you already have the switchport trunk allowed vlan [vlan-id] command and add another vlan then yes you will not block any other vlan in the list.
Francisco.
09-03-2008 05:05 AM
That's perfect. Thanks.
09-03-2008 04:25 AM
by default, all vlans allowed on the trunk link so yes you will because you are limiting the vlan allowed on the trunk. only the vlan you allowed with the "switchport trunk allowed vlan [vlan-id]" command will work on the trunk link.
use the "switchport trunk allowed vlan [vlan-id]" comamnd on both switches to permit the vlans on the trunk link
