Adding a seocnd / sub DHCP pool
random260
Community Member
We have the configuration below set up in a 3560 switch (addresses and names modified for privacy). We are running out of dynamic IP’s in the current pool (6.35.159.0 – 6.35.159.255). We have a new set of IP’s that we can use (6.44.56.0 – 6.44.57.255 – an additional 512 addresses). Although I can figure out the commands to add a new dhcp pool, secondary subnet, etc., I’ve never done this before so I’m not sure of everything I need to do. The end result I need is that the 3560 needs to be able to hand out IP addresses from the current and new pool to anything connecting to vlan 300 – our datanet where computers access the Internet. Can someone take a look at the configuration below and tell me exactly what I need to do as far as modifying the vlan, adding the secondary subnet, defining helper IP’s, gateways, whatever, so that computers connecting via vlan 300 have Internet access via either of the pools?  I have been told that all I need to do is create the pool, but not sure if that is correct...
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.07.12 09:31:53 =~=~=~=~=~=~=~=~=~=~=~=
show running-config
Building configuration...
Current configuration : 5727 bytes
! Last configuration change at 14:10:57 UTC Thu May 31 2012 by user1
! NVRAM config last updated at 14:14:46 UTC Thu May 31 2012 by user1
version 12.2
no service pad
hostname Business-Core
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$DY7I$MfTqxNyT9H.1pkF9W8E681
username userold password 0 funyjoke
username user1 password 0 sunnyvale
--More--         !
aaa new-model
aaa authentication login default local
aaa session-id common
system mtu routing 1500
authentication mac-move permit
no ip subnet-zero
ip routing
ip dhcp excluded-address 6.35.159.1 6.35.159.25
ip dhcp pool DHCP_Pool1
   network 6.35.159.0 255.255.255.0
   default-router 6.35.159.1
   dns-server 8.8.8.8 8.8.4.4
   domain-name funnybiz.net
   lease 0 8
--More--         ip domain-name funnybiz.net
ip name-server 6.35.158.4
mls qos
spanning-tree mode rapid-pvst
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
spanning-tree backbonefast
spanning-tree vlan 5,200,300,400,738 priority 4096
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
--More--         !
interface Loopback100
no ip address
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
shutdown
interface GigabitEthernet0/1
no switchport
ip address dhcp
interface GigabitEthernet0/2
description datafarm A DNS/DHCP
switchport access vlan 200
switchport mode access
interface GigabitEthernet0/3
interface GigabitEthernet0/4
--More--         !
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
description datafarm A HA
spanning-tree portfast
interface GigabitEthernet0/11
description datafarm B HA
--More--         interface GigabitEthernet0/12
switchport trunk allowed vlan 200,300,400
switchport mode trunk
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
description laptop test port
switchport access vlan 300
spanning-tree bpdufilter enable
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
--More--         switchport access vlan 300
interface GigabitEthernet0/19
shutdown
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
--More--         !
interface GigabitEthernet0/24
interface GigabitEthernet1/1
description Interface to link 3 Network
no switchport
ip address 7.15.134.62 255.255.255.252
ip access-group 100 in
speed nonegotiate
interface GigabitEthernet1/2
speed nonegotiate
interface GigabitEthernet1/3
interface GigabitEthernet1/4
--More--         interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan200
description CORE IP Network
ip address 6.35.158.1 255.255.255.128
hold-queue 1000 in
interface Vlan300
description Access Network
ip address 6.35.159.1 255.255.255.0
ip helper-address 6.35.159.1
no ip redirects
no ip mroute-cache
interface Vlan400
ip address 6.35.158.129 255.255.255.128
hold-queue 1000 in
--More--         !
interface Vlan735
no ip address
interface Vlan738
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 4.28.134.61
ip route 6.35.158.0 255.255.255.128 Vlan200
ip route 6.35.158.128 255.255.255.128 Vlan400
ip route 6.35.159.0 255.255.255.0 Vlan300
no ip http server
no ip http secure-server
ip sla enable reaction-alerts
access-list 100 permit tcp 63.209.193.0 0.0.0.63 6.35.158.128 0.0.0.127 range 5060 5061
access-list 100 permit tcp 63.209.193.0 0.0.0.63 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 permit udp 63.209.193.0 0.0.0.63 6.35.158.128 0.0.0.127 range 5060 5061
--More--         access-list 100 permit udp 63.209.193.0 0.0.0.63 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 permit tcp 208.85.134.0 0.0.0.255 6.35.158.128 0.0.0.127 range 5060 5061
access-list 100 permit tcp 208.85.134.0 0.0.0.255 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 permit udp 208.85.134.0 0.0.0.255 6.35.158.128 0.0.0.127 range 5060 5061
access-list 100 permit udp 208.85.134.0 0.0.0.255 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 deny   tcp any 6.35.158.128 0.0.0.127 range 5060 5061
access-list 100 deny   tcp any 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 deny   udp any 6.35.158.128 0.0.0.127 range 5060 5061
access-list 100 deny   udp any 6.35.158.0 0.0.0.127 range 5060 5061
access-list 100 permit ip any any
no cdp run
snmp-server community public RO
line con 0
line vty 0 4
exec-timeout 60 0
transport input ssh
--More--         line vty 5 15
exec-timeout 60 0
transport input ssh
monitor session 1 source interface Gi1/1
monitor session 1 destination interface Gi0/16
ntp clock-period 36027429
ntp source GigabitEthernet1/1
ntp server 64.90.182.55
end
Business-Core#exit
darren.g
Level 10
Level 10
Steven.
As far as I know, you can't do that. You can't have a DHCP server allocating IP addresses in a completely different subnet for the network involved - and you've specified you want VLAN300 to have allocations from *both* pools.
What you could do is create another VLAN and put your "new" nodes into that VLAN - or spread your ports across VLAN's and move the load into the second pool - call it VLAN 301 and just duplicate your existing configurations for VLAN 300 (changing IP addresses as necessary) - but I don't know of a way to do what you want in one VLAN.
Sorry I can't be more help.
Sandeep Choudhary
HI Steven,
We vcan not configure  2 diff network on a single dhcp pool.
If you wasnt then you can create 2 shcp pool and then assign the address, it will work
Please rate if it helps.
Rick Morris
Level 11
Level 11
Here is a DHCP configuration guide to assist you.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html
With 2 different subnets you will need 2 different DHCP pools.
