2960S privilege level problem
the-lebowski
Level 8
Level 8
I have a handful of 2960s that I have privilege levels configured for our QA department to login and change vlan port assignments.  I configured them identically but one will not allow that user to change vlans.
The commands that I am using on all of the switches (that works on the other two) are below:
privilege interface level 5 switchport
privilege interface level 5 description
privilege configure level 5 interface
privilege exec level 5 configure terminal
privilege exec level 5 show vlan
privilege exec level 5 show running-config
The user logs in via Radius (NPS) and has the privilege level set to 5 there, so when they login the perms match and they can do what I allow them to.  However on a certain 2960 it gives them this when attempting to change the vlan:
sw86#show privilege
Current privilege level is 5
sw86#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ws86(config)#int gi1/0/31
sw86(config-if)#switchport acc?
% Unrecognized command
ON a working switch (identical privilege commands...I copied them from there):
sw88#show privilege
sw88#conf t
sw88(config)#int gi1/0/7
sw88(config-if)#sw
sw88(config-if)#switchport acc
sw88(config-if)#switchport access vlan ?
  <1-4094>  VLAN ID of the VLAN when this port is in access mode
Any idea what or where the problem is?
5 Replies 5
the-lebowski
Level 8
Level 8
I figured it out if anyone else runs into this problem.  You have to explicity allow the entire command:
privilege interface level 5 switchport access vlan
But even after you do that entire command wont show in the config.  It will just show "
privilege interface level 5 switchport"
Weird but its working correctly now.
Matthew Blanshard
What version of software on the switch? Looks like a bug to me.
c2960s-universalk9-mz.122-58.SE1.bin
All of my 2960s are running that IOS.
This is all it shows when I do a show run:
Compared to a 3750 (c3750-advipservicesk9-mz.122-46.SE.bin) I have with the same commands, it shows the ‘switchport access vlan’ command whereas the 2960 does not.
I have filed bug CSCtr81355 to document this issue and to get it fixed.  You can view the bug at this link:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtr81355
It will take 24h for it to populate into the database.
-Matt
Update to this.
Minor workaround..the commands are stored in the startup-config so I can always copy/paste from there.
