Air Gap Environment / Cat 9300/9600
a customer bought a bunch of Cat 9300 and 9600 with Version 17.3.3. the Switches are located in an air gap environment. so they will never be connected to the cloud or a CSSM. This environment should run at least 2 years without "touching it".
What happens after 365 days or when the advantage/essential license expires and they cant connect to cloud or CSSM?
Do they stop working?
Thanks in advance
Leo Laohoo
Leo Laohoo
NOTHING will happen.
New Deployment Method for Smart Licensing
Arshad Safrulla
Cisco is not enforcing any license restrictions on 9000 series switches yet. So I am sure it will not hinder the operations of the switch. Meanwhile you can consider using SLR/PLR for licensing.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst_slr/b-169-9000-series-SLR-cg/b-169-9000-series-SLR-cg_chapter_00.html
