AP fail to join controller
maldini.vivek
Hi all,
I am using a controller Cisco 7500 Series Wireless LAN Controller running Software Version 8.0.133.0
Trying to connect a AP cisco AIR-LAP1041N-E-K9 running code C1140-K9W8-M
I get below error, Any help on this is appreciated.
8.0.133.0 release not says this model is supported.
(WLC) >show ap join stats det 68:bc:0c:c8:a5:70
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 5
- Successful discovery responses sent...................... 5
- Unsuccessful discovery request processing................ 0
- Reason for last unsuccessful discovery attempt........... Not applicable
- Time at last successful discovery attempt................ Sep 14 10:13:33.535
- Time at last unsuccessful discovery attempt.............. Not applicable
Join phase statistics
- Join requests received................................... 2
- Successful join responses sent........................... 2
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Sep 14 10:13:44.544
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
- Configuration requests received.......................... 0
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Not applicable
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Data transfer message received from an unsupported AP
- Last AP disconnect reason................................ Not applicable
Last join error summary
- Type of error that occurred last......................... AP got or has been disconnected
- Reason for error that occurred last...................... Data transfer message received from an unsupported AP
- Time at which the last join error occurred............... Sep 14 10:15:14.599
Ethernet Mac : 68:bc:0c:c8:a5:70 Ip Address : x.x.x.
the 1140 series actually appears to be suppported by this release (8.0.133.0). Is your AP by any chance associated with the WLC in local mode ? If that is the case, this feature is not supported, and you should convert to FlexConnect or Monitor mode. Check out the link below for other features not supported in release 8.0.133.0:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr3.html#pgfId-1163026
rafafilho11
Controller 8500
Version 8.0.152
Access-point flex connect mode
(Cisco Controller) >show ap join stats detailed my:ma:c
- Time at sync request received............................ Apr 25 23:29:25.527
- Time at sync completed................................... Apr 25 23:29:25.530
- Discovery requests received.............................. 249
- Successful discovery responses sent...................... 123
- Unsuccessful discovery request processing................ 126 <------------Maybe a firewall ?
- Reason for last unsuccessful discovery attempt........... Missing AP Manager interface
- Time at last successful discovery attempt................ Jul 11 12:35:26.388
- Time at last unsuccessful discovery attempt.............. Jul 11 12:35:26.389
- Join requests received................................... 22 ---> Join pahse is ok
- Successful join responses sent........................... 22 ---> Join pahse is ok
- Time at last successful join attempt..................... Jul 11 12:35:42.732
- Configuration requests received.......................... 56
- Successful configuration responses sent.................. 19
- Time at last successful configuration attempt............ Jul 11 12:35:42.999
- Reason for last AP connection failure.................... Image data request received from an unsupported AP
- Last AP disconnect reason................................ Unknown failure reason
- Type of error that occurred last......................... Lwapp discovery request rejected
- Reason for error that occurred last...................... Missing AP Manager interface
- Time at which the last join error occurred............... Jul 11 12:35:26.389
Ethernet Mac : my:ma:c Ip Address : 17.7.20.18
