02-21-2013 04:06 PM - edited 03-07-2019 11:52 AM
Is it possible to configure both Catalyst WS-C2960-24PC-L and Switch Cisco SG300-28 to work together for VLANs for voice and data ? If yes, can you give me the resources which I can refer to ?
02-21-2013 06:15 PM
WS-C2960-24PC-L can be used for data and voice sine it is POE switch.
SG300-28 doesn't appear to be a POE switch. So only data.
02-21-2013 09:49 PM
The WS-C2960-24PC-L can be used for data and voice sine it is POE switch.
If I use the SG300-28P that it´s a POE switch.
Can I pass vlan from voice and data from Catalyst to SG300 y vs?
02-21-2013 10:05 PM
Hi Armin,
Yes SG300-28P is the POE switch.
I am not sure what exactly you mean by your second question but anyway yes both voice and data vlan are supported on this switch.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html
Inayath
02-23-2013 09:17 AM
Hi, I have no idea why anyone is associating POE with the capability to pass voice traffic... but that is certainly not the question being asked nor is it a valid point since POE has nothing to do with a voice vlan passing....
The answer is yes, these switches can work together. The SG300 supports 802.1q and not VTP. When configuring the SG300 you have to specify a native vlan and the tagged vlans on the port.
If your 2960 has a LLDP or Voice policy through CDP, the SG300 is capable to pick up this configuration through its smart port macros.
Here are is a topic where I configured a 2960 to feed LLDP configuration to a SG300-52
https://supportforums.cisco.com/thread/2180209
-Tom
Please mark answered for helpful posts
